跳转至内容 跳转至侧边栏
Waiting for author
Topic Tags: Compatibility
Overview of the issue
When using Meta Box with WPML, the ‘Post’ relationship field defined via Meta Box is not automatically populated with translated posts IDs, leaving the translated post without a valid relationship.
Workaround
  • Add the following code to your theme’s functions.php file.
    add_filter( 'rwmb_meta', 'compsupp_8073_translate_parent_post_id', 10, 4 );
    function compsupp_8073_translate_parent_post_id( $value, $key, $args, $post_id ) {
        if ( $key === 'parent_post' && ! empty( $value ) && is_numeric( $value ) ) {
            $current_lang = apply_filters( 'wpml_current_language', null );
            $value = apply_filters( 'wpml_object_id', $value, 'parent-post', true, $current_lang );
        return $value;
  • Replace 'parent_post' with the actual Meta Box field name used for your relationship.
发表回复
保持话题相关并尊重他人。如果您需要与本帖无关的问题帮助,请使用我们的支持论坛开始聊天或提交工单。
您可以使用这些标签:
