跳过导航
Open
Reported for: BuddyPress Multilingual 1.7.0
Overview of the issue
When using Redis Object Cache or Object Cache Pro with BuddyPress Multilingual you will experience problems with BuddyPress pages. In some situations, pages won’t display and in others, you will be incorrectly redirected.
This is caused by the bp_pages cache group which does not hold language information.
Workaround
By default, Redis Object Cache already excludes the groups “themes”, “plugins” and “counts”. The solution is to exclude the “bp_pages” group as well.
To do this, add the following lines to your wp-config.php file.
define( 'WP_REDIS_IGNORED_GROUPS', [
    "counts",
    "plugins",
    "themes",
    "bp_pages"
In case you are using Object Cache Pro plugin, add the groups in WP_REDIS_CONFIG file as explained here:
'non_persistent_groups' => [
    'counts',
    'plugins',
    'themes',
    'bp_pages'
Alternatively, you can also follow the instructions of this another erratum.
3 所有回复 给 “Problems with BuddyPress Multilingual and Redis Object Cache or Object Cache Pro”
留下回复
紧扣主题并尊重他人。如果您需要帮助解决与本帖无关的问题,请使用我们的 Support Forum 开始聊天或提交票据。
您可以使用这些标签:
