跳到内容 跳到侧边栏
Waiting for author
Topic Tags: Compatibility
Overview of the issue
If you are using U-Design theme, you might not be able to fully translate some Blocks and Widgets.
Workaround
  • Go to WPML > Settings > Custom XML Configuration page.
  • Paste the following code in the text area:
    <wpml-config>
      <gutenberg-blocks>
        <!-- UDesign Heading Block -->
        <gutenberg-block type="udesign/udesign-heading" translate="1">
          <key name="title">
            <key name="title*" />
          </key>
        </gutenberg-block>
        <!-- UDesign Button Block -->
        <gutenberg-block type="udesign/udesign-button" translate="1">
          <key name="label">
            <key name="label*" />
          </key>
          <key name="link">
            <key name="link*" />
          </key>
        </gutenberg-block>
        <!-- UDesign Icon Block -->
        <gutenberg-block type="udesign/udesign-icon" translate="1">
          <key name="source">
            <key name="source*" />
          </key>
          <key name="dynamic_content">
            <key name="dynamic_content*" />
          </key>
          <key name="link">
          </key>
        </gutenberg-block>
        <!-- UDesign Image Block -->
        <gutenberg-block type="udesign/udesign-image" translate="1">
          <key name="img_source">
            <key name="img_source*" />
          </key>
          <key name="block_id">
            <key name="block_id*" />
          </key>
        </gutenberg-block>
        <!-- UDesign Container Block -->
        <gutenberg-block type="udesign/udesign-container" translate="1">
          <key name="attributes">
            <key name="attributes*" />
          </key>
        </gutenberg-block>
      </gutenberg-blocks>
      <elementor-widgets>
        <widget name="udesign_widget_alert">
          <fields>
            <field>title</field>
            <field>description</field>
          </fields>
        </widget>
        <widget name="udesign_widget_block">
          <fields>
            <field>name</field>
          </fields>
        </widget>
        <widget name="udesign_widget_brands">
          <fields>
            <field>show_brand_products</field>
            <field>brands</field>
          </fields>
        </widget>
        <widget name="udesign_widget_breadcrumb">
          <fields>
            <field>delimiter</field>
          </fields>
        </widget>
        <widget name="udesign_widget_countdown">
          <fields>
            <field>type</field>
            <field>label</field>
            <field>date</field>
          </fields>
        </widget>
        <widget name="udesign_widget_iconlist">
          <fields>
            <field>icon_list</field>
          </fields>
          <fields-in-item items_of="icon_list">
            <field>text</field>
            <field editor_type="LINK">url</field>
          </fields-in-item>
        </widget>
        <widget name="udesign_widget_circles_info">
          <fields>
            <field>items</field>
          </fields>
          <fields-in-item items_of="items">
          </fields-in-item>
        </widget>
        <widget name="udesign_widget_marquee">
          <fields>
            <field>text_content</field>
          </fields>
        </widget>
        <widget name="udesign_widget_products">
          <fields>
            <field>items_list</field>
          </fields>
          <fields-in-item items_of="items_list">
            <field>item_col_span>size</field>
            <field>item_row_span>size</field>
          </fields-in-item>
        </widget>
        <widget name="udesign_widget_timeline">
          <fields>
            <field>timeline_list</field>
          </fields>
          <fields-in-item items_of="timeline_list">
            <field>meta</field>
            <field>desc</field>
            <field>breakpoint_text</field>
          </fields-in-item>
        </widget>
        <widget name="udesign_widget_timeline_horizontal">
          <fields>
            <field>timeline_custom_line</field>
          </fields>
            <field>meta</field>
            <field>desc</field>
            <field>active_item</field>
          </fields-in-item>
        </widget>
      </elementor-widgets>
    </wpml-config>
  • Click Save.
  • Apply a small edit to your post.
  • Translate the post.
发表回复
您可以使用这些标签:
