跳到内容 跳到侧边栏
Resolved
Resolved in: WPML Multilingual CMS 4.7.4
Topic Tags: Compatibility
Overview of the issue
Elementor Pro’s experimental Taxonomy Filter feature, which is currently in Alpha, exhibits issues when used with the Loop Grid on translated pages and it fails to display the expected results.
Workaround
Please, make sure of having a full backup of your site before proceeding.
Part I
  • Open …/wp-content/plugins/elementor-pro/modules/loop-filter/widgets/taxonomy-filter.php file.
  • Look for line 691.
  • Just after:
    		$widget_data = Utils::find_element_recursive( $document->get_elements_data(), $this->get_settings_for_display( 'selected_element' ) );
  • Add this code:
    		if (isset($widget_data['settings']['post_query_include_term_ids'])) {
    			$translated_data = [];
    			foreach ($widget_data['settings']['post_query_include_term_ids'] as $term_id) {
    				$translated_data[] = get_term($term_id)->term_id;
    			$widget_data['settings']['post_query_include_term_ids'] = $translated_data;
Part II
  • Open your theme’s functions.php file.
  • Add the following code:
     * @link wpmlsupp-11444
    add_filter( 'elementor/query/query_args', function( $query_args ) {
    	$translated_query_args = $query_args;
    	if (isset($query_args['tax_query'])) {
    		foreach ($query_args['tax_query'] as $key => $query) {
    			if (isset($query['field']) && in_array($query['field'], ['term_id', 'term_taxonomy_id'], true)) {
    				$query['terms'] = array_map(function( $id ) use ($query){
    					return apply_filters( 'wpml_object_id', $id, $query['taxonomy'], TRUE  );
    				}, (array) $query['terms']);
    				$translated_query_args['tax_query'][$key] = $query;
    	return $translated_query_args;
    }, 100 );
9 个回复 至 “Elementor Pro - "Taxonomy Filter" Feature Not Working for Secondary Language”
  1. Hello, this solution works for me, but when there are an update of elementor, the “taxonomy-filter.php” file is update too, and the modification disappear… have you a solid and maintenable solution for that ?
    Many thanks !
    • Hi Pierre,
      Thanks for reaching out! Unfortunately, I can’t provide an ETA for this issue, but it has been escalated to our developers. In the meantime, when you update Elementor Pro, you’ll need to follow the steps in Part I again. The code should now be around line 712. Thanks for your understanding!
