Open
Topic Tags: Compatibility
Overview of the issue
The Fancy Chart block from Essential Blocks plugin, currently it is not translatable using WPML’s Advanced Translation Editor.
Workaround
At the moment, there is no direct solution to make the Fancy Chart block translatable. Instead, you can use the manual editor and input translations directly.
留下回复
Please stay on topic and be respectful to others. If you need help with issues not related to this post, use our Support Forum to start a chat or submit a ticket.
您可以使用这些标签:
