跳到内容 跳到侧边栏
Resolved
Resolved in: WPML Multilingual CMS 4.7.4
Overview of the issue
If you use single quotes within Flatsome UX Builder modules, the following paragraph text won’t be available for translation in WPML’s Classic or Advanced Translation Editors.
Workaround
Our developers are working on it. In the meantime, you can replace the single quotes for an HTML element:
For example, instead of:
[title text="It's HOW WE MAKE THESE SUPPLEMENTS." tag_name="h4"]
Use an HTML element:
7 个回复 至 “Flatsome Theme - UX Builder contents are not showing for translation in the Classic or Advanced Translation Editors”
  1. Hello, I have the same issue. Some texts of my flatsome website are not being showed in the classic wpml editor. on the other hand, if I translate via the UX builder, it often changes back to to the incorrect version after a few minutes. also links in buttons are not leading to the right path.
