跳到内容 跳到侧边栏
Open
Topic Tags: Compatibility
Overview of the issue
When using SiteOrigin’s Layout Builder, there are issues with translating widgets that are duplicated both inside and outside the layout builder on the same page. As result, they are not translatable.
Workaround
Please, make sure of having a full backup of your site before proceeding.
  • Open …/wp-content/plugins/sitepress-multilingual-cms/addons/wpml-page-builders/classes/Integrations/SiteOrigin/TranslatableNodes.php file.
  • Look for line 142.
  • Change:
    1
    2
    3
    public function get_string_name( $node_id, $field, $settings ) {
            return $node_id . '-' . $settings[ self::SETTINGS_FIELD ]['id'] . '-' . $field['field'];
  • For:
    1
    2
    3
        return $node_id . '-' . $settings[ self::SETTINGS_FIELD ]['widget_id'] . '-' . $field['field'];
  • Do a small modification on the original page and save.
  • Update the translation.
发表回复
您可以使用这些标签:
