跳过导航
Open
Topic Tags: Compatibility
Overview of the issue
With the Ultimate Addons for Beaver Builder plugin, currently it is not possible to translate the Heading module in our Advanced Translation Editor.
Workaround
  • Navigate to WPML > Configuration > Custom XML Configuration page.
  • Add the following XML:
    <wpml-config>
    	<beaver-builder-widgets>
    		<widget name="uabb-heading">
    			<fields>
    				<field type="Heading title" editor_type="LINE">heading</field>
    				<field type="Heading content" editor_type="LINE">description</field>
    			</fields>
    		</widget>
      </beaver-builder-widgets>
    </wpml-config>
You can find more information about it here.
留下回复
Please stay on topic and be respectful to others. If you need help with issues not related to this post, use our Support Forum to start a chat or submit a ticket.
您可以使用这些标签:
