跳到内容 跳到侧边栏
Resolved by author
Resolved in: WooCommerce Product Options 2.6.0
Topic Tags: Compatibility, WCML
Overview of the issue
When using WooCommerce Product Options by Barn2 with WPML, Product option strings appear as untranslated on cart, checkout, and mini-cart, even though they are correctly translated on the product page.
Workaround
  • In your theme’s functions.php file, paste the following code:
     * Translate WooCommerce Product Options texts when adding to cart
     * using the plugin's own WPML integration.
    add_filter( 'woocommerce_add_cart_item_data', 'my_wpo_translate_cart_meta_with_wpml', 20, 4 );
    function my_wpo_translate_cart_meta_with_wpml( $cart_item_data, $product_id, $variation_id, $quantity ) {
        // If there are no WPO options in this cart item, do nothing.
        if ( empty( $cart_item_data['wpo_options'] ) ) {
            return $cart_item_data;
        // Make sure the plugin classes exist (plugin is active and loaded).
        if (
            ! class_exists( 'Barn2PluginWC_Product_OptionsPlugin_Factory' ) ||
            ! class_exists( 'Barn2PluginWC_Product_OptionsIntegrationWPML' ) ||
            ! class_exists( 'Barn2PluginWC_Product_OptionsModelOption' )
        // Get the plugin instance and the WPML integration helper.
        $plugin           = Barn2PluginWC_Product_OptionsPlugin_Factory::create( '', '' );
        $wpml_integration = new Barn2PluginWC_Product_OptionsIntegrationWPML( $plugin );
        foreach ( $cart_item_data['wpo_options'] as $option_id => &$option_data ) {
            // Load the option model so we can access the original data.
            $option = Barn2PluginWC_Product_OptionsModelOption::find( $option_data['option_id'] ?? 0 );
            if ( ! $option ) {
                continue;
            // 1) Translate the option name (the "key" shown in cart/checkout).
            $translated_name     = $wpml_integration->translate_string( $option->name, $option, 'option_name' );
            $option_data['name'] = $translated_name;
            // 2) Translate each choice label, if any.
            if ( empty( $option_data['choice_data'] ) || empty( $option->choices ) ) {
                continue;
            // Build a map: choice_id => index, to reproduce the same index WPML uses.
            $index_by_id = [];
            foreach ( $option->choices as $idx => $choice ) {
                if ( isset( $choice['id'] ) ) {
                    $index_by_id[ $choice['id'] ] = $idx;
            // Normalize the stored value to an array (covers both single and multi).
            $values = is_array( $option_data['value'] ) ? $option_data['value'] : [ $option_data['value'] ];
            foreach ( $option_data['choice_data'] as $i => &$choice_data ) {
                if ( ! isset( $choice_data['label'] ) ) {
                    continue;
                // For free-text fields, there are usually no predefined choices to translate.
                if ( empty( $index_by_id ) ) {
                    continue;
                $value_for_this_choice = $values[ $i ] ?? null;
                if ( ! isset( $index_by_id[ $value_for_this_choice ] ) ) {
                    continue;
                $choice_index   = $index_by_id[ $value_for_this_choice ];
                $original_label = $option->choices[ $choice_index ]['label'];
                // Translate the choice label using the same context and index as when registered.
                $choice_data['label'] = $wpml_integration->translate_string(
                    $original_label,
                    $option,
                    'choice_label',
                    $choice_index
  • Note: If you change language after having products in your cart, the labels will not be “translated”: they remain in the language that was active when the product was added (just like any other metadata that stores fixed texts). But it’s rare switching languages at that stage.
    A permanent fix will soon be applied by Barn2, please remove the added workaround when it is deployed
