콘텐츠로 건너뛰기 사이드바로 건너뛰기
3
WPML Multilingual & Multicurrency for WooCommerce is a very important project for us, today we are happy to announce that we have 3 WooCommerce extensions to add to our compatibility list.
The extensions are Checkout field editor, WooCart Pro, Product Slider Pro
The checkout field editor provides you with an interface to add, edit and remove fields shown on your WooCommerce checkout page.
Purchase Checkout field editor
WooCart Pro
WooCart Pro is powerful plugin to create and modify the cart for your online shop.
Purchase WooCart Pro
Product Slider Pro
WooCommerce product slider is a jQuery powered and carouFredsel library based posts content slider plugin developed for WordPress.
Purchase Product Slider Pro
