Перейти к содержанию Перейти к боковой панели
Помечено:
Эта тема содержит 0 ответ, имеет 1 голос.
Последнее обновление: przemyslawD-3 10 месяцев, 3 недели назад.
При содействии: Bruno Kos.
Автор Посты
4 сентября, 2024 в 9:39 дп
przemyslawD-3
I had to restore the database because during yesterday's support work many translations in the Swiss version disappeared. Now I want to repeat all the steps according to the instructions, but it does not solve the problem.
https://wpml.org/forums/topic/problem-with-woocommerce-product-filter-in-each-language-apart-basic/
Screencast: скрытая ссылка
Problem with WooCommerce product filter in each language apart from the basic language.
How can I fix the WooCommerce product filter issue in each language apart from the basic language?
Why did the translations in the Swiss version disappear after the support work?
What steps should I follow to correctly restore the database and translations?
4 сентября, 2024 в 11:22 дп
