דלג לתוכן דלג לסרגל צד
תגיות:
נושא זה מכיל 0 1, יש ל 1קוֹל.
עודכן לאחרונה על ידי przemyslawD-3 לפני שנה 1, חודש 6.
בסיוע: Bruno Kos.
מחבר פוסטים
4 בספטמבר 2024 ב-9:39
przemyslawD-3
I had to restore the database because during yesterday's support work many translations in the Swiss version disappeared. Now I want to repeat all the steps according to the instructions, but it does not solve the problem.
https://wpml.org/forums/topic/problem-with-woocommerce-product-filter-in-each-language-apart-basic/
Screencast: קישור נסתר
Problem with WooCommerce product filter in each language apart from the basic language.
How can I fix the WooCommerce product filter issue in each language apart from the basic language?
Why did the translations in the Swiss version disappear after the support work?
What steps should I follow to correctly restore the database and translations?
