WPML
Panoramica del problema
Quando utilizzi il plugin Bookings for WooCommerce con WPML e WooCommerce Multilingual, un prodotto prenotabile tradotto non ottiene le impostazioni di prenotazione del prodotto originale. La pagina del prodotto tradotto non mostra alcun calendario delle prenotazioni né servizi e il totale della prenotazione è di 0,00 $.
Soluzione alternativa
  1. Vai a WPMLImpostazioni e apri la scheda Configurazione XML personalizzata.
  2. Aggiungi questo codice e salva:
    XML
    <wpml-config>
      <custom-fields>
        <custom-field action="copy">mwb_mbfw_booking_criteria</custom-field>
        <custom-field action="copy">wps_mbfw_booking_type</custom-field>
        <custom-field action="copy">mwb_mbfw_booking_count</custom-field>
        <custom-field action="copy">mwb_mbfw_booking_unit</custom-field>
        <custom-field action="copy">mwb_mbfw_enable_calendar</custom-field>
        <custom-field action="copy">mwb_mbfw_enable_time_picker</custom-field>
        <custom-field action="copy">mwb_mbfw_max_bookings</custom-field>
        <custom-field action="copy">mwb_mbfw_show_date_with_time</custom-field>
        <custom-field action="copy">mwb_mbfw_admin_confirmation</custom-field>
        <custom-field action="copy">mwb_mbfw_cancellation_allowed</custom-field>
        <custom-field action="copy">mwb_mbfw_booking_unit_cost</custom-field>
        <custom-field action="copy">mwb_mbfw_booking_base_cost</custom-field>
        <custom-field action="copy">mwb_mbfw_booking_base_cost_hide</custom-field>
        <custom-field action="copy">mwb_mbfw_booking_general_cost_hide</custom-field>
        <custom-field action="copy">mwb_mbfw_show_additional_cost_details</custom-field>
        <custom-field action="copy">mwb_cost_date_range_notice</custom-field>
        <custom-field action="copy">mwb_mbfw_is_people_option</custom-field>
        <custom-field action="copy">mwb_mbfw_minimum_people_per_booking</custom-field>
        <custom-field action="copy">mwb_mbfw_maximum_people_per_booking</custom-field>
        <custom-field action="copy">mwb_mbfw_is_booking_unit_cost_per_people</custom-field>
        <custom-field action="copy">mwb_mbfw_is_booking_base_cost_per_people</custom-field>
        <custom-field action="copy">mwb_mbfw_minimum_no_days_booking</custom-field>
        <custom-field action="copy">mwb_mbfw_maximum_booking_per_unit</custom-field>
        <custom-field action="copy">mwb_mbfw_is_add_extra_services</custom-field>
        <custom-field action="copy">mwb_mbfw_daily_calendar_start_time</custom-field>
        <custom-field action="copy">mwb_mbfw_daily_calendar_end_time</custom-field>
        <custom-field action="copy">mwb_mbfw_choose_holiday</custom-field>
        <custom-field action="copy">mwb_mbfw_booking_time_fromat</custom-field>
        <custom-field action="copy">wps_mbfw_day_and_days_upto_togather_enabled</custom-field>
        <custom-field action="copy">wps_mbfw_night_slots_enabled</custom-field>
        <custom-field action="copy">mwb_mbfw_booking_hide_or_diable_slot</custom-field>
        <custom-field action="copy">wps_mbfw_set_availability</custom-field>
        <custom-field action="copy">wps_mbfw_set_availability_upto</custom-field>
        <custom-field action="copy">wps_mbfw_time_slots</custom-field>
        <custom-field action="copy">mwb_bfwp_order_statuses_to_cancel</custom-field>
        <custom-field action="copy">_dynamic_pricing_enabled</custom-field>
        <custom-field action="copy">_dynamic_pricing_rules</custom-field>
        <custom-field action="copy">_available_days</custom-field>
        <custom-field action="copy">_non_available_days</custom-field>
        <custom-field action="copy">_booking_default_price</custom-field>
      </custom-fields>
      <custom-term-fields>
        <custom-term-field action="copy">mwb_mbfw_service_cost</custom-term-field>
        <custom-term-field action="copy">mwb_mbfw_is_service_optional</custom-term-field>
        <custom-term-field action="copy">mwb_mbfw_is_service_hidden</custom-term-field>
        <custom-term-field action="copy">mwb_mbfw_is_service_has_quantity</custom-term-field>
        <custom-term-field action="copy">mwb_mbfw_service_minimum_quantity</custom-term-field>
        <custom-term-field action="copy">mwb_mbfw_service_maximum_quantity</custom-term-field>
        <custom-term-field action="copy">mwb_mbfw_is_service_cost_multiply_people</custom-term-field>
        <custom-term-field action="copy">mwb_mbfw_is_service_cost_multiply_duration</custom-term-field>
      </custom-term-fields>
    </wpml-config>
  3. Traduci di nuovo i tuoi prodotti prenotabili, oppure aggiorna le traduzioni, in modo che WPML copi le impostazioni di prenotazione.
Tutti i problemi noti
Hai bisogno di aiuto con questo problema?
Fai una richiesta di supporto e la esamineremo con te.
