Open
Reported for: Advanced Custom Fields Multilingual 2.0.5
Topic Tags: Compatibility
Overview of the issue
Currently is not possible to translate external links in Advanced Custom Fields (ACF) when the field group is set to “Same fields across languages” mode.
Workaround
  • Go to ACF > Field Groups page
  • Edit Field Group: Access the ACF field group settings.
  • Switch to Expert Mode: Change the configuration to “Expert” mode.
  • Adjust Translation Preferences: For each URL field, set the “Translation Preferences” to “Translate.”
  • Trigger Translation Job: Make a minor edit to the original page/post to generate a new translation job.
  • Check Translation Availability: The URLs should now be available for translation in the WPML Translation Editor.
Lascia una risposta
Puoi usare questi tag:
