Open
Reported for: Advanced Custom Fields Multilingual 2.1.5
Topic Tags: Compatibility
Overview of the issue
When using Advanced Custom Fields (ACF) with WPML, you might experience issues with conditional logic not functioning correctly in secondary languages. This happens when the conditional logic depends on fields that use object-based or term-based references, such as taxonomy or post object fields.
Workaround
  • Add the following code to your theme’s functions.php file.
     * WPML Workaround for compsupp-wpmltriage-3649
    add_action( 'init', function() {
    	if ( defined( 'ICL_SITEPRESS_VERSION' ) ) {
    		add_filter( 'acf/load_field', function ( $field ) {
    			if ( empty( $field['conditional_logic'] ) || ! is_array( $field['conditional_logic'] ) ) {
    				return $field;
    			foreach ( $field['conditional_logic'] as $group_index => $rules ) {
    				if ( ! is_array( $rules ) ) {
    					continue;
    				foreach ( $rules as $rule_index => $rule ) {
    					if ( isset( $rule['field'], $rule['value'] ) && is_numeric( $rule['value'] ) ) {
    						// Fetch the parent field
    						$parent_field = acf_get_field( $rule['field'] );
    						if ( ! isset( $parent_field['type'] ) ) {
    							continue;
    						if ( $parent_field['type'] === 'taxonomy' ) {
    							$rule['value'] = apply_filters( 'wpml_object_id', $rule['value'], $parent_field['taxonomy'], true );
    						} elseif ( $parent_field['type'] === 'post_object' ) {
    							$post_types = $parent_field['post_type'] ?? ''; // can be multiple
    							if ( is_array( $post_types ) ) {
    								foreach ( $post_types as $post_type ) {
    									$translated_id = apply_filters( 'wpml_object_id', $rule['value'], $post_type, true );
    									if ( $translated_id && $translated_id !== $rule['value'] ) {
    										$rule['value'] = $translated_id;
    										break;
    							} else {
    								$rule['value'] = apply_filters( 'wpml_object_id', $rule['value'], $post_types, true );
    						$field['conditional_logic'][ $group_index ][ $rule_index ] = $rule;
    			return $field;
    		}, 100 );
Deixe uma resposta
Por favor mantenha-se no assunto e seja respeitoso com os outros. Se precisar de ajuda com problemas não relacionados a este post, use nosso Fórum de Suporte para iniciar um chat ou enviar um ticket.
Você pode usar estas tags:
