Open
Topic Tags: Compatibility
Overview of the issue
If you are using the RSVP Pro plugin, you may encounter issues where some strings do not display as translated on the frontend when using WPML. This problem typically arises due to the string’s unique key exceeding the character limit set by the system, resulting in mismatched keys and untranslated strings.
Workaround
  • Open the app/public/wp-content/plugins/rsvp-pro-plugin/includes/rsvp-utils.inc.php file
  • Look for line 1069.
  • Replace:
    function rsvp_pro_get_dynamic_translated_string( $key_name, $string, $event_id ) {
    	$text = $string;
    	if ( function_exists( 'pll__' ) ) {
    		$text = pll__( $string );
    	if ( has_filter( 'wpml_translate_string' ) ) {
    		$event_name = rsvp_pro_get_event_name( $event_id );
    		$package    = array(
    			'kind'  => "RSVPPro - {$event_id}",
    			'name'  => "rsvp-pro-plugin-{$event_id}",
    			'title' => "RSVP Pro Plugin - {$event_name}",
    		$key_name   = strtolower( $key_name );
    		$key_name   = str_replace( ' ', '-', $key_name );
    		$text       = apply_filters( 'wpml_translate_string', $string, $key_name, $package );
    	return $text;
  • With:
    	$text = $string;
    		$package    = array(
    		// WPML Workaround for compsupp-7503
    		$key_name = substr($key_name, 0, 160);
    	return $text;
Deixe uma resposta
Por favor mantenha-se no assunto e seja respeitoso com os outros. Se precisar de ajuda com problemas não relacionados a este post, use nosso Fórum de Suporte para iniciar um chat ou enviar um ticket.
Você pode usar estas tags:
