Pular a navegação
Resolved by author
Reported for: WPML SEO 2.1.0
Resolved in: SEOPress 8.4
Topic Tags: Compatibility
Overview of the issue
When using SEOPress plugin with WPML, the product archive slugs are not correctly translated in the XML sitemaps generated by SEOPress.
Workaround
  • Open …/wp-content/plugins/wp-seopress/templates/sitemap/single.php file.
  • Look for line 41.
  • Replace:
    // WPML Workaround
    if (class_exists('SitePress')) {
    	if ( 2 != apply_filters( 'wpml_setting', false, 'language_negotiation_type' ) ) {
    		$original_language = apply_filters( 'wpml_current_language', NULL );
    		$language_list = apply_filters( 'wpml_active_languages', NULL, 'orderby=id&order=desc' );
    		if (!empty($language_list)) {
    			foreach ($language_list as $key => $language_infos ) {
    				if ($original_language != $language_infos['language_code']) {
    					// Switch Language
    					do_action( 'wpml_switch_language', $language_infos['language_code']);
    					$archive_links[] = htmlspecialchars(urldecode(user_trailingslashit(get_post_type_archive_link($path))));
    					// Restore language to the original
    					do_action( 'wpml_switch_language', $original_language);
  • With:
    // WPML Workaround for compsupp-7538 and compsupp-6419
    if ( class_exists('SitePress' )) {
    					// Switch Language
    					if ( $path == 'product' && function_exists('wc_get_page_id') ) {
    						$shop_page_id = wc_get_page_id('shop');
    						$archive_links[] = 	htmlspecialchars(urldecode(user_trailingslashit(get_permalink($shop_page_id))));
    					} else {
Deixar uma Resposta
Por favor, mantenha-se no tópico e respeite os outros. Se você precisar de ajuda com problemas não relacionados a esta postagem, use nosso Fórum de suporte para iniciar um bate-papo ou enviar um tíquete.
Você pode usar estas tags:
