Open
Reported for: WPML Multilingual & Multicurrency for WooCommerce 5.2.0
Topic Tags: Compatibility
Overview of the issue
If you buy a product in second languages, you will notice that it is not assignment of a membership. You can observe this specifically in the “Thank you” page that follows the order, where the expected membership details are absent.
Workaround
Please, make sure of having a full backup of your site before proceeding.
  • Open the …/wp-content/plugins/woocommerce-memberships/src/class-wc-memberships-membership-plan.php file.
  • Look for line 218.
  • Replace:
    public function get_product_ids() {
    	if ( null === $this->product_ids ) {
    		$this->product_ids = get_post_meta( $this->id, $this->product_ids_meta, true );
    		$this->product_ids = is_array( $this->product_ids ) ? array_unique( array_map( 'absint', $this->product_ids ) ) : [];
    	return $this->product_ids;
  • With:
    		$this->product_ids = apply_filters( 'wc_memberships_rule_object_ids', $this->product_ids );
Deixe uma resposta
Por favor mantenha-se no assunto e seja respeitoso com os outros. Se precisar de ajuda com problemas não relacionados a este post, use nosso Fórum de Suporte para iniciar um chat ou enviar um ticket.
Você pode usar estas tags:
