Resolved by author
Topic Tags: Compatibility
Overview of the issue
If you are using Hestia Pro theme, you may experience an issue where the custom Footer layout created in Appearance > Custom layouts is displayed only in the default language, regardless of the translations available for the layout.
Workaround
Please, make sure of having a full backup of your site before proceeding.
  • Open …/wp-content/themes/hestia-pro/inc/addons/modules/custom_layouts/class-hestia-custom-layouts-module.php file.
  • Look for line 210.
  • Change:
    	private function map_custom_layouts() {
    		if ( $this->is_builder_preview() ) {
    			return true;
    		$cache = get_transient( 'custom_layouts_posts_map' );
    		if ( ! empty( $cache ) ) {
    			self::$post_map = $cache;
    			return true;
    		$query = new WP_Query(
    			array(
    				'post_type'              => 'hestia_layouts',
    				'posts_per_page'         => 100,
    				'no_found_rows'          => true,
    				'update_post_meta_cache' => false,
    				'update_post_term_cache' => false,
    				'fields'                 => 'ids',
    				'post_status'            => 'publish',
    		if ( ! $query->have_posts() ) {
    			return false;
    		foreach ( $query->posts as $pid ) {
    			$layout   = get_post_meta( $pid, 'custom-layout-options-layout', true );
    			$priority = get_post_meta( $pid, 'custom-layout-options-priority', true );
    			if ( $layout === 'hooks' ) {
    				$layout = get_post_meta( $pid, 'custom-layout-options-hook', true );
    			self::$post_map[ $layout ][ $pid ] = $priority;
    		set_transient( 'custom_layouts_posts_map', self::$post_map, DAY_IN_SECONDS );
    		return true;
  • With:
    			return true;
    		// Get the current language code
    		$current_language = apply_filters('wpml_current_language', NULL); // Fallback to WPML's current language
    		// Modify the transient key to include the current language
    		$wpml_transient_key = 'custom_layouts_posts_map_' . $current_language;
    		$cache = get_transient( $wpml_transient_key );
    			return true;
    			array(
    				'fields'                 => 'ids',
    			return false;
    		set_transient( $wpml_transient_key, self::$post_map, DAY_IN_SECONDS );
    		return true;
  • After that, delete your transients.
