Open
Topic Tags: Compatibility
Overview of the issue
In some cases, Oxygen Builder templates translations are not displayed correctly for logged-out visitors.
Workaround
Please, make sure of having a full backup of your site before proceeding and keep in mind that Oxygen is not currently compatible with WPML.
  • Install a plugin like WP Code and make sure the snippet is read as a PHP code.
  • Add the following snippet:
    add_action( 'init', 'wpml_ct_add_templates_cpt' );
    function wpml_ct_add_templates_cpt() {
    	$labels = array(
    		'name'               => _x( 'Templates', 'post type general name', 'component-theme' ),
    		'singular_name'      => _x( 'Template', 'post type singular name', 'component-theme' ),
    		'menu_name'          => _x( 'Templates', 'admin menu', 'component-theme' ),
    		'name_admin_bar'     => _x( 'Template', 'add new on admin bar', 'component-theme' ),
    		'add_new'            => _x( 'Add New Template', 'template', 'component-theme' ),
    		'add_new_item'       => __( 'Add New Template', 'component-theme' ),
    		'new_item'           => __( 'New Template', 'component-theme' ),
    		'edit_item'          => __( 'Edit Template', 'component-theme' ),
    		'view_item'          => __( 'View Template', 'component-theme' ),
    		'all_items'          => __( 'Templates', 'component-theme' ),
    		'search_items'       => __( 'Search Templates', 'component-theme' ),
    		'parent_item_colon'  => __( 'Parent Templates:', 'component-theme' ),
    		'not_found'          => __( 'No templates found.', 'component-theme' ),
    		'not_found_in_trash' => __( 'No templates found in Trash.', 'component-theme' )
    	$args = array(
    		'exclude_from_search' => true,
    		'labels'             => $labels,
    		'public'             => true,
    		'publicly_queryable' => true,
    		'has_archive'		 => true,
    		'show_ui'            => true,
    		'show_in_menu'       => 'ct_template',
    		'rewrite' 			 => false,
    		'query_var'          => true,
    		'capability_type'    => 'post',
    		'hierarchical'       => false,
    		'menu_position'      => null,
    		'supports'           => array( 'title' )
    	register_post_type( 'ct_template', $args );
  • Translate your Oxygen templates using WordPress Editor.
Lascia una risposta
Puoi usare questi tag:
