Resolved by author
Topic Tags: Compatibility
Overview of the issue
The Fancy Chart block from Essential Blocks plugin, currently it is not translatable using WPML’s Advanced Translation Editor.
Workaround
At the moment, there is no direct solution to make the Fancy Chart block translatable. Instead, you can use the manual editor and input translations directly.
