Open
Overview of the issue
If you use single quotes within Flatsome UX Builder modules, the following paragraph text won’t be available for translation in WPML’s Classic or Advanced Translation Editors.
Workaround
Our developers are working on it. In the meantime, you can replace the single quotes for an HTML element:
For example, instead of:
[title text="It's HOW WE MAKE THESE SUPPLEMENTS." tag_name="h4"]
Use an HTML element:
7 Respostas para “Flatsome Theme - UX Builder contents are not showing for translation in the Classic or Advanced Translation Editors”
  1. Hello, I have the same issue. Some texts of my flatsome website are not being showed in the classic wpml editor. on the other hand, if I translate via the UX builder, it often changes back to to the incorrect version after a few minutes. also links in buttons are not leading to the right path.
    • Hey there,
      If the workaround here displayed doesn’t help in your case, please start a chat in our support system.
      We will investigate your case and try to provide you an alternative workaround.
Deixar uma Resposta
Please stay on topic and be respectful to others. If you need help with issues not related to this post, use our Support Forum to start a chat or submit a ticket.
Você pode usar estas tags:
