Waiting for author
Topic Tags: Compatibility
Overview of the issue
When using YITH WooCommerce Badge Management Premium, badges assigned to products do not display on their translated versions. This issue arises because certain metadata required for badge display is not copied or synced to the translated products.
Workaround
1. Add Custom XML Configuration
  • Go to WPML > Settings > Custom XML Configuration
  • Paste the following code and click “Save”
    <wpml-config>
      <custom-fields>
        <custom-field action="copy">_yith_wcbm_badge_from_date</custom-field>
        <custom-field action="copy">_yith_wcbm_badge_ids</custom-field>
        <custom-field action="copy">_yith_wcbm_badge_schedule</custom-field>
        <custom-field action="copy">_yith_wcbm_badge_to_date</custom-field>
      </custom-fields>
    </wpml-config>
2. Set Badge Post Type to “Not Translatable”
  • Go to WPML > Settings > Post Types Translation
  • Locate Badges (yith-wcbm-badge) and set it to Not translatable
3. Translate Badge Text
  • Go to WPML > String Translation
  • Locate the badge text under the yith-woocommerce-badges-management domain and translate it.
Deixe uma resposta
Por favor mantenha-se no assunto e seja respeitoso com os outros. Se precisar de ajuda com problemas não relacionados a este post, use nosso Fórum de Suporte para iniciar um chat ou enviar um ticket.
Você pode usar estas tags:
