Resolved
Reported for: WPML Multilingual CMS 4.6.7
Resolved in: WPML 4.7.0
Topic Tags: Compatibility
Overview of the issue
When utilizing Elementor Pro with WPML to build and translate pop-ups, the inline CSS for the translated pop-ups may not be rendered correctly. This leads to small visual discrepancies between the original and translated versions.
Workaround
Please, make sure of having a full backup of your site before proceeding.
  • Open …/wp-content/plugins/elementor-pro/modules/popup/tag.php file.
  • Look for line 99.
  • Change:
    	public function render() {
    		$settings = $this->get_active_settings();
    		if ( 'close' === $settings['action'] ) {
    			$this->print_close_popup_link( $settings );
    			return;
    		$this->print_open_popup_link( $settings );
  • For:
    		return;
    	// WPML Workaround for compsupp-7039
    	if ( class_exists('Sitepress') && isset($settings['popup']) ) {
    		$settings['popup'] = apply_filters( 'wpml_object_id', $settings['popup'], get_post_type($settings['popup']) , TRUE  );
2 risposte a “Elementor Pro - Inline CSS not rendered for translated pop-ups”
