Open
Overview of the issue
After updating WordPress to version 6.7.1, strings from the Germanized for WooCommerce Pro plugin are not being translated into German as expected.
Workaround
- Open the …/wp-content/plugins/woocommerce-germanized-pro/includes/class-wc-gzdp-wpml-helper.php file.
- Look for line 112.
- Replace:
public function reload_locale() { unload_textdomain( 'woocommerce-germanized-pro' ); WC_germanized_pro()->load_plugin_textdomain(); } - With:
public function reload_locale() { unload_textdomain( 'woocommerce-germanized-pro', true ); WC_germanized_pro()->load_plugin_textdomain(); } - Then open the …/wp-content/plugins/woocommerce-germanized-pro/woocommerce-germanized-pro.php file.
- Look for line 772.
- Change the order of these two lines:
load_textdomain( 'woocommerce-germanized-pro', trailingslashit( WP_LANG_DIR ) . 'woocommerce-germanized-pro/woocommerce-germanized-pro-' . $locale . '.mo' ); load_plugin_textdomain( 'woocommerce-germanized-pro', false, plugin_basename( __DIR__ ) . '/i18n/languages/' );
- With:
load_plugin_textdomain( 'woocommerce-germanized-pro', false, plugin_basename( __DIR__ ) . '/i18n/languages/' ); load_textdomain( 'woocommerce-germanized-pro', trailingslashit( WP_LANG_DIR ) . 'woocommerce-germanized-pro/woocommerce-germanized-pro-' . $locale . '.mo' );
Good day,
I’m afraid it already says
in the file you mentioned. The issue persists.
To be more precise:
The mentioned fix works, BUT ONLY if there is no translation file at /wp-content/languages/wpml/
As soon as you edit at least one string for Germanized Pro, so that a .mo file is created at /wp-content/languages/wpml/, the fix falls apart and everything is English again for Germanized Pro.
Hello Martin,
Could you please open a ticket in our support forum? In that way, we will be able to investigate your case and help you to find a solution. Please mention this erratum to the supporter handling your ticket
Hi Martin, We’ve updated the workaround with an extra step.
Thanks for the update. I can confirm that it works after these two steps.
The first step has already been fixed by the Germanized Pro authors in the newest version of Germanized Pro. The second issue still remains in their code.
we have exactly the same issue! Germanized support told us that some Germanized Pro Strings are registered wrong in the Database. There is no fix available and this has to be fixed manually in den DB – but how??
Hi Paul,
Thanks for reporting this issue in your support ticket. As Marcel mentioned, we don’t recommend manually changing the strings stored in the database.
We’ve already escalated your feedback to our second-tier support team and will keep you updated directly in your ticket.
Hi Paul, We’ve updated the workaround with an extra step.
