Waiting for author
Topic Tags: Compatibility
Overview of the issue
When using Grid Builder with WPML and Advanced Custom Fields (ACF), there’s a problem with Facets using custom fields. Even though the ACF field labels are translated in the backend, they are not reflected in the frontend.
Workaround
Please, make sure of having a full backup of your site before proceeding.
For Select fields
  • Open your theme’s functions.php file.
  • Add the following code:
    // WPML Workaround for wpmlsupp-11647
    function wpml_wpmlsupp11647_translate_facet_choices( $choices, $facet ) {
    	if ( class_exists('Sitepress') ) {
    		foreach ($choices as &$choice) {
    			$string = $choice->facet_name;
    			$textdomain = 'facets';
    			$string_name = 'Facet: '.substr($string, 0, 20);
    			if ( apply_filters('wpml_default_language', NULL ) == apply_filters( 'wpml_current_language', NULL )) {
    				do_action( 'wpml_register_single_string', $textdomain, $string_name, $string );
    			// Apply the translation to the string
    			$choice->facet_name = apply_filters('wpml_translate_single_string', $string , $textdomain, $string_name);
    	return $choices;
    add_filter( 'wp_grid_builder/facet/choices', 'wpml_wpmlsupp11647_translate_facet_choices', 10, 2 );
  • Visit the page with the facets in the original language to register the strings.
  • Go to WPML > String Translation page and translate the strings.
Note: Depending on how your Facets were built, this other snippet may be helpful:
// WPML Workaround for compsupp-7453
function wpml_compsupp7453_translate_facet_block_custom_field( $output ) {
        if( is_string($output) ) {
            $string = $output;
            $output = apply_filters('wpml_translate_single_string', $string , $textdomain, $string_name);
    return $output ;
add_filter( 'wp_grid_builder/block/custom_field', 'wpml_compsupp7453_translate_facet_block_custom_field', 99, 2 );
2 risposte a “Grid Builder - Facets using ACF fields labels are not translated in frontend”
  1. I haven’t had any luck with this. Is anything in the code specific to the website? Do I need to make any changes?
    I was able to get Facets to register in the string translation, and I’ve translated them, but the facets still aren’t appearing on the front end.
    • Hello there,
      There is nothing specific per website, so this workaround should work out of the box.
      If this doesn’t help, please start a chat in our assistance channel, we will investigate your case.
Lascia una risposta
Per favore rimani in tema e sii rispettoso verso gli altri. Se hai bisogno di aiuto per problemi non relativi a questo post, usa il nostro Forum di Supporto per iniziare una chat o inviare un ticket.
Puoi usare questi tag:
