Waiting for author
Topic Tags: Compatibility
Overview of the issue
If you are using Premmerce Permalink Manager for WooCommerce and Elementor, you will notice that if you create a new product or edit an existing product and set a custom product permalink structure, Elementor will open it in a Safe Mode.
Workaround
2 risposte a “Premmerce Permalink Manager for WooCommerce - Elementor only opens in Safe Mode when using a custom product permalink”
    • Hello Vinenzo,
      At the moment we don’t have a workaround and the author haven’t join our efforts to solve it.
      We recommend you to contact him or consider using another already WPML compatible plugin:
      https://wpml.org/plugin
Lascia una risposta
Puoi usare questi tag:
