Waiting for author
Topic Tags: Compatibility
Overview of the issue
When using the Post Carousel widget from the Unlimited Elements for Elementor plugin on a site with WPML, the widget fails to fetch translated posts, leading to content display issues on translated pages.
Workaround
Please, make sure of having a full backup of your site before proceeding.
  • Open your theme’s functions.php file.
  • Add the following code:
    // WPML Workaround for compsupp-7126
    add_filter( 'elementor/frontend/before_render', 'wpml_compsupp7126_filter_ucaddon_post_carousel');
    function wpml_compsupp7126_filter_ucaddon_post_carousel($element) {
        if ( 'ucaddon_post_carousel' !== $element->get_name() ) {
            return;
        $settings = $element->get_settings();
        if ( isset( $settings['post_manual_select_post_ids'] ) && is_array( $settings['post_manual_select_post_ids'] ) ) {
            foreach ( $settings['post_manual_select_post_ids'] as $key => $id ) {
                $post_type = get_post_type( $id );
                if ( ! $post_type ) {
                    continue;
                $id = apply_filters( 'wpml_object_id', $id, $post_type, true );
                unset($settings['post_manual_select_post_ids'][$key]);
                $settings['post_manual_select_post_ids'][] = $id;
            $element->set_settings( 'post_manual_select_post_ids', $settings['post_manual_select_post_ids'] );
Lascia una risposta
Puoi usare questi tag:
