Salta la navigazione
Open
Topic Tags: Compatibility
Overview of the issue
When using the new Product Safety feature from Germanized, there is an issue with translating manufacturer data and syncing these details in product translations.
Workaround
1. Ensure manufacturers are correctly translated
  • Navigate to Products → Manufacturer.
  • Verify that all manufacturer terms are translated and saved properly.
2. Set the translation preference
  • Go to WPML → Settings → Custom Fields Translation.
  • Click on “Show system fields”.
  • Locate the field '_manufacturer_slug' and set its translation preference to Copy Once.
  • 3. Edit the original to update the translation
    • Make a small change in the original product (like adding a space after a paragraph) and save.
    • The manufacturer data and related fields will automatically sync to the translation.
    Lasciare una risposta
    Ti preghiamo di rimanere in tema e di essere rispettoso nei confronti degli altri. Se hai bisogno di aiuto per questioni non correlate a questo post, utilizza il nostro Forum di supporto per avviare una chat o inviare un ticket.
    Potete usare questi tag:
