Open
Reported for: BuddyPress Multilingual 1.7.0
Overview of the issue
There’s an inconsistency in the alphabetical sorting of translated taxonomy fields on the BuddyBoss profile pages. While the default language fields are sorted correctly, the translated fields do not maintain this order.
Workaround
- Open …/wp-content/plugins/buddyboss-platform/bp-xprofile/classes/class-bp-xprofile-field-type-selectbox.php file.
- Inside
BP_XProfile_Field_Type_Selectbox::edit_field_options_html()
, replace the following line:1echo
$html
- With:
123456789101112131415161718192021222324252627282930
// WPML Workaround for compsupp-7514
if
class_exists
'Sitepress'
) && apply_filters(
'wpml_default_language'
, NULL ) != apply_filters(
'wpml_current_language'
, NULL ) ) {
// Match all options
preg_match_all(
'/<option(.*?)>(.*?)<\/option>/s'
$html
$matches
, PREG_SET_ORDER);
// Extract the options into an array
$optionsArray
foreach
$matches
as
$match
$optionsArray
'full'
$match
[0],
'attributes'
$match
[1],
'text'
$match
[2],
// Sort the array by the 'text' element
usort(
$optionsArray
function
$a
$b
return
strcmp
$a
'text'
$b
'text'
// Rebuild the HTML string
$sortedHtml
foreach
$optionsArray
as
$option
$sortedHtml
.= sprintf(
'<option%s>%s</option>'
$option
'attributes'
$option
'text'
$html
$sortedHtml
echo
$html
