Pular navegação
Este tópico foi resolvido. Aqui está uma descrição do problema e da solução.
You are trying to display posts on your English URL using a Search and Filter plugin, but the posts are not showing, unlike the Portuguese version of the site.
The issue was due to missing configurations for the plugin to function correctly in English. Specifically, the Advanced Custom Fields (ACF) were not set up for translation. We have now configured them properly on your site. To complete the setup, you need to send all posts for automatic translation or translate them manually. This should resolve the issue. For detailed guidance on setting up ACF for multilingual sites, please visit Advanced Custom Fields (ACF) Multilingual - Translate all fields with WPML.
If this solution does not apply to your case, or if it seems outdated, we recommend opening a new support ticket. We also highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, please contact us through the WPML support forum.
Este é o fórum de suporte técnico para o WPML — o plugin de WordPress multilíngue.
Todos podem ler, mas apenas clientes do WPML podem postar aqui. A equipe do WPML responde no fórum 6 dias por semana, 22 horas por dia.
Marcado:
Este tópico contém 0, tem 0 vozes.
Última atualização: Lucas Vidal de Andrade 4 meses, 1 semana atrás.
Assistido por: Lucas Vidal de Andrade.
Autor Posts
fevereiro 14, 2025 às 12:22 pm
maria-aliceL
Histórico da questão:
I am trying to display posts on my English URL link oculto using a Search and Filter plugin. The Portuguese version at link oculto displays correctly.
Sintomas:
The English URL does not show posts, and nothing is displayed.
Perguntas:
Why does the English URL not display posts with the Search and Filter plugin?
How can I make the English page display the same elements as the Portuguese page?
fevereiro 14, 2025 às 1:34 pm
fevereiro 14, 2025 às 1:57 pm #16706718
Apoiador do WPML desde 11/2023
Idiomas: Inglês (English ) Espanhol (Español ) Alemão (Deutsch ) Português (Português )
Fuso horário: America/Sao_Paulo (GMT-03:00)
Eu já enviei o seu ticket para os nossos desenvolvedores e te retornarei assim que obtiver uma resposta.
fevereiro 14, 2025 às 5:48 pm #16707728
Hey there,
We suspect this is a broader compatibility issue with WPML and Search & Filter Pro. To verify that, I've created a testing environment, so we can analyze the plugin in isolation. You can access it here:
link oculto
Please install Search & Filter Pro, create a CPT and recreate the page with the results, the same way you did on your website. Please note that the idea here is to verify the functioning in isolation, so please don't import or create any content, settings, or plugins that are not directly related to the issue. Only the minimum is necessary. I know this takes some effort, so thank you in advance for the cooperation.
Let me know when you're done.
fevereiro 14, 2025 às 6:20 pm #16707793
maria-aliceL
Ok, fiz a instalação e configuração do plugin Search Filter.
Também fiz a configuração da Home Page assim como é no meu site.
fevereiro 17, 2025 às 11:33 am #16713689
Olá Maria,
No seu site, você possui um CPT, um elemento de busca e outro de resultados, configurados no Search & Filter. Como a ideia é verificar o funcionamento do plugin junto deste conteúdo traduzido, você pode também recriar esta parte?
Em resumo: precisamos de uma página como a que está no seu site, mostrando os resultados de um CPT. Novamente, sei que isso toma esforço, então desde já agradeço a cooperação.
Qualquer coisa, me avise. Obrigado.
fevereiro 17, 2025 às 5:43 pm #16715897
maria-aliceL
Pronto, criei o CPT e configurei no filtro, o mesmo já aparece na página inicial.
fevereiro 17, 2025 às 6:36 pm #16716017
Obrigado. Assim que eu obtiver uma resposta dos nossos desenvolvedores, eu te retorno.
fevereiro 17, 2025 às 6:40 pm #16716019
maria-aliceL
Ok, esperamos muito uma solução, se não precisaremos cancelar a assinatura.
fevereiro 20, 2025 às 7:38 pm #16731169
Olá,
Obrigado por aguardar. Eu recebi retorno dos nossos desenvolvedores. Haviam várias configurações faltando no site, para que o form funcionasse em inglês.
No momento, falta apenas atualizar os apoios. Os ACFs não estavam configurados para serem traduzidos, como está explicado aqui:
https://wpml.org/pt-br/documentacao/projetos-relacionados/advanced-custom-fields-acf-multilingue-traduza-todos-os-campos-com-o-wpml/
Eu configurei-os corretamente no seu site. Para finalizar, é necessário que você envie todos os apoios para tradução automatica, ou traduza-os manualmente. Isso resolverá o problema.
fevereiro 20, 2025 às 7:44 pm #16731214
maria-aliceL
Acredito que já esta em processo de atualização. confirma?
fevereiro 21, 2025 às 11:19 am #16733276
Sim.
Pode verificar se tem créditos suficientes em WPML > Translation Management > Translation Tools. Muitos dos “apoios” tinham conteúdos não traduzidos, pelo que a sua tradução necessitará de créditos.
