Questo ticket contiene 0 risposte, ha 1 voce.
Ultimo aggiornamento da domenicoS-18 1 settimana, 1 giorno fa.
Autore Post
Aprile 22, 2026 alle 11:38 #17987331
domenicoS-18
I hope you are doing well.
I am currently facing an issue with Slider Revolution on my website while working with WPML for Spanish translations. I have created the Spanish version of my sliders and updated all the necessary links from the backend within Slider Revolution.
However, the problem is that the updated links are not reflecting on the frontend. Despite confirming that the links are correctly updated in the backend editor, the frontend continues to display the old or incorrect links.
I would appreciate it if you could: Check whether this is a compatibility issue between WPML and Slider Revolution.
Thank you for your support. I look forward to your guidance in resolving this matter.
Aprile 22, 2026 alle 11:41 #17987337
domenicoS-18
hhf
