works fine for a single apartment in WP Rentals. Before that code change you proposed, the reviews were visible only on the original language, they were not visible in the other languages.
However I have found that if I activate a second apartment on WP Rentals, all the same reviews for the "Stunning sea views..." apartment are also visible on the new apartment, instead of showing only reviews that are corresponding to the right apartment.
Basically the code changes that were done are not filtering by the right listing post-id.
Could you please help to fix that?
The code changes that were proposed by WPML team were:
$comments_query = new WP_Query( $args );
$comments = $comments_query->posts;
@@ -802,4 +816,4 @@ if (!function_exists('wpestate_query_vars')) {
-add_filter('query_vars', 'wpestate_query_vars');
No newline at end of file
+add_filter('query_vars', 'wpestate_query_vars');
Le sujet '[Fermé] Solution proposed for https://wpml.org/forums/topic/issues-translating-a-site-with-wp-rentals-2/ is …' est fermé aux nouvelles réponses.
