Saltar navegación
Zona horaria del soporte: America/Lima (GMT-05:00)
Este tema contiene 5 respuestas, tiene 2 voces.
Última actualización por Andreas W. hace 11 meses.
Asistido por: Andreas W..
julio 11, 2024 a las 4:34 pm #15936556
xavierc-4
Antecedentes del problema:
On the WordPress Backend post / page list + Advanced Custom Fields PRO, If I click on a language to see the translated pages / posts, appears nothing.
Síntomas:
Preguntas:
julio 11, 2024 a las 6:31 pm #15937077
Partidario de WPML desde 12/2018
Idiomas: Inglés (English ) Español (Español ) Alemán (Deutsch )
Zona horaria: America/Lima (GMT-05:00)
You need to install our addon Advanced Custom Fields Multilingual to be able to translate ACF.
Please read this guide:
You can find the addon at Plugins > Add new > Commercial.
Make sure that the ACF Field Groups are set to "Not translate" and if you have already translated field groups, please delete the translations.
Then on your field groups set the proper translation method.
If you translate the content that is using the fields with the WordPress Editor, please use the field group setting "Different fields across languages". This will set up all the field's translation preference settings automatically.
julio 12, 2024 a las 9:56 am #15941539
xavierc-4
Thanks! I don't need to translate ACF, I just need that the wordpress native post / page's editor works on each language. If I deactivate ACF PRO it works, but when activated, it doesn't.
julio 12, 2024 a las 6:30 pm #15943958
Thank you for the clarification.
It is very unlikely that ACF PRO is causing this, as this plugin is compatible with WPML.
There must be another active plugin that is causing this problem.
Could you please create a copy/stage of the site and try running the site with minimal setup to see if the problem persists?
1) Disable any additional plugins unrelated to WPML and our add-ons. Now test again.
2) If this didn't resolve the issue, please switch to a default theme like Twenty Twenty-One to see if the problem might be related to the theme.
3) If this still does not clarify what is causing the issue, start reactivating the plugins one by one or activate them in small groups. Do this to check where the problem is reoccurring to see which plugin is causing the problem.
Once we have been able to identify the cause, we can then attempt to replicate the problem and then escalate it internally. In this case, I provide a test site with WPML.
In case the issue persists while testing with a default theme and only WPML plugins, then I need access to your site for further investigation.
If you are having issues with running those tests, then please let me know and I will offer you my assistance.
julio 16, 2024 a las 11:03 am #15960063
xavierc-4
thanks Andreas W!
I see that on a brand new WP instalation + WPML + ACF PRO the problem appears just as mentioned.
Thanks! Guillermo
julio 16, 2024 a las 11:30 am #15960206
Here is a link to a new WP install with ACF PRO and WPML:
enlace oculto
I can not confirm such an issue here. Please try to recreate the issue using the same settings as you do on your site.
If you can not confirm the issue on this test site, please create a copy/stage of the site and try running the site with minimal setup to see if the problem persists:
1) Disable any additional plugins unrelated to ACF PRO, WPML, and our add-ons. Now test again.
2) If this didn't resolve the issue, please switch to a default theme like Twenty Twenty-One to see if the issue might be related to the theme.
El tema “[Cerrado] ACF PRO with WPML not showing translated posts on Page / Posts (of CPT)” está cerrado a nuevas respuestas.
