The client is trying to synchronize categories, products, and images between the French and Dutch versions of their WooCommerce site. The French version displays correctly, but the Dutch version does not, showing discrepancies in categories, product counts, and images.
1. For categories and taxonomies, go to WooCommerce > WooCommerce Multilingual > Settings > troubleshooting at the bottom of the page and try all the available options.
2. For images, launch the media translation tool under WPML > Settings > Media Translation. Then, go to WPML > Support > troubleshooting and try all the following buttons (select Products then Media for taxonomy synchronization).
3. Refer to the WPML troubleshooting documentation for detailed steps: https://wpml.org/documentation/support/wpml-troubleshooting-options/
4. If the homepage is not translated, preventing language switching, use the translation editor to complete the translation as shown here: https://prnt.sc/BUAeqXt95f75
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket for further assistance.
Dernière mise à jour par Ilyes Il y a 6 mois et 2 semaines.
Assisté par: Ilyes.
Auteur Messages
février 6, 2025 à 8:35 pm #16677273
stephanieD-19
Contexte de la question:
Je tente de synchroniser les catégories, produits, et photos sur mon site. Le problème est visible sur la page : lien caché. J'attendais à voir : lien caché.
Symptômes:
Les catégories, le nombre de produits, et les photos ne correspondent pas entre les versions française et néerlandaise du site. Le français est correct, mais le néerlandais ne l'est pas.
Comment synchroniser correctement les catégories, produits, et photos entre les versions linguistiques du site ?
février 7, 2025 à 10:33 pm #16681390
Ilyes
Bonjour,
Merci d'avoir contacté l'équipe de support WPML,
Pour les catégories et les taxonomies, allez sur WooCommerce > WooCommerce Multilingual > Settings > troubleshooting (en bas de la page) et essayez toutes les options qui s'y trouvent.
Pour les photos, vous pouvez lancer l'outil de traduction des médias sous WPML > Paramètres > Traduction des médias : lien caché
Ensuite, allez sur WPML > Support > troubleshooting et essayez tous les boutons suivants (sélectionnez Products puis Media pour la synchronisation de la taxonomie) : lien caché
Vous pouvez vous référer à cette documentation pour savoir comment faire : https://wpml.org/documentation/support/wpml-troubleshooting-options/
Meilleure solution,
février 8, 2025 à 11:17 am #16682079
stephanieD-19
Bonjour,
j'ai tout fait, cela ne change rien, il doit y avoir un truc qui bloque ....
vous ne savez pas jeter un oeil?
lien caché -> FR EST OK
lien caché -> NL pas ok ..
ça ne se synchronise pas...
Merci,
février 10, 2025 à 4:04 pm #16688699
stephanieD-19
Bonjour, avez-vous trouvé le bug?
merci,
Stéphanie
février 11, 2025 à 4:36 pm #16692935
Ilyes
Bonjour Stéphanie,
J'aimerais vous demander un accès temporaire au wp-admin et au FTP de votre site de test, ce qui me permettra de trouver ces informations pour vous,
Il est important de noter que vous devez sauvegarder votre site et votre base de données avant de procéder, et vous pouvez utiliser un plugin comme Duplicator à cette fin. Voici un lien vers ce plugin : http://wordpress.org/plugins/duplicator/
Si vous ne voyez pas le formulaire ci-dessous, n'entrez pas vos informations d'identification, car elles seront exposées publiquement :
lien caché
Pour des raisons de confidentialité et de sécurité, veillez à ce que votre réponse soit privée.
février 12, 2025 à 11:01 pm #16699474
Ilyes
Bonjour,
J'ai découvert qu'il y a 702 produits dans les catégories pédicure en français, mais seulement 513 en néerlandais, plusieurs produits néerlandais sont définis dans Draft et tous les produits ne sont pas traduits, ce qui explique pourquoi les nombres ne correspondent pas,
Voici un exemple :
- lien caché
- lien caché
Ces deux produits font partie de la catégorie Pédicure / INSTRUMENTS & MATERIEL DE PEDICURE / BOITES & PLATEAUX EN INOX , il y a 15 produits en français, et 13 en néerlandais, parce que ces deux produits ne sont pas traduits.
Il en va de même pour toutes les autres catégories.
Et puis j'ai trouvé quelque chose d'intéressant, que l'on peut voir dans cette capture d'écran : lien caché
Le problème se produit dans la langue d'origine même si les plugins WPML sont désactivés : lien caché
La catégorie « PINCES A ONGLES » est censée afficher 39 produits, mais en français, et sans WPML, elle n'en affiche qu'un. Si vous cliquez sur cette catégorie, toutes les marques s'affichent correctement, mais le décompte est erroné.
Comme si le modèle de page de la catégorie ne comptait pas les sous-catégories sous Pinces, similaire à ce qui est rapporté ici :
lien caché
https://wordpress.stackexchange.com/questions/238114/woocoomerce-product-category-count-including-subcategories
En résumé :
1- Au premier niveau, il faut d'abord signaler ce problème à Woocommerce, car les Pinces et autres catégories n'affichent pas le bon décompte, le décompte n'inclut pas les sous-catégories.
2- Ensuite, une fois que le décompte est correct sur l'original, c'est là qu'il faut compléter et publier la traduction de tous les produits manquants.
Enfin, pour les images, j'ai simplement réenregistré les catégories avec les images manquantes : lien caché
J'espère que cela vous a aidé à mieux comprendre la nature du problème,
février 13, 2025 à 4:58 pm #16703894
stephanieD-19
Bonjour,
Je vais essayer cela, par contre, avant, sur ma page d'accueil, sous le lien du menu "Francais" j'avais le dropdown "Néerlandais" pour accéder au contenu néerlandophone, 'est-ce parce-que je n'ai pas encore traduit en Néerlandais? Comment faire au mieux pour traduire cette page en Néerlandais? Merci
février 13, 2025 à 10:16 pm #16704635
Ilyes
Vous avez raison, votre page d'accueil n'est pas traduite, c'est pourquoi vous ne pouvez pas changer de langue, il vous suffit de cliquer sur l'icône plus pour ouvrir l'éditeur de traduction et terminer la traduction comme indiqué ici : lien caché
