Sun
Mon
Tue
Wed
Thu
Fri
Sat
9:00 – 14:00
9:00 – 14:00
9:00 – 14:00
9:00 – 14:00
9:00 – 14:00
15:00 – 18:00
15:00 – 18:00
15:00 – 18:00
15:00 – 18:00
15:00 – 18:00
Fuseau horaire du supporter: Asia/Dhaka (GMT+06:00)
Contexte de la question:
Je souhaite désactiver totalement WPML sur mon site lien caché. J'ai réalisé toutes les manipulations conseillées par WPML.
Symptômes:
Cela crée toujours des problèmes sur mon site. Mon site et la base de données sont corrompus par des anciens éléments laissés par le plugin WPML.
Pouvez-vous me transmettre une solution pour désactiver totalement WPML?
Existe-t-il un plugin de nettoyage pour supprimer toute trace de WPML?
To reduce the waiting time, I took this ticket and responded in English. Please let me know if you're okay with it or if you want to continue the conversation in French language. I will check and forward this ticket to one of our French-speaking supporters to assist you in the French language.
I understand what you're looking for. Typically, WPML data can be removed from the database by resetting the plugin. However, it's recommended to delete the language first before resetting, as this will allow you to remove all the associated data within that language. Doing so ensures that the translated content in the specific language is fully removed.
Additionally, after removing the language and its contents, you can take further steps to ensure a complete cleanup before resetting.
- Please go to WPML > Support > troubleshooting
- Click on the following buttons:
-- Clear the cache in WPML
-- Remove ghost entries from the translation tables
The WPML data should be removed from the database after following the instructions above. However, if you need further assistance or clarification for any particular steps, feel free to let me know. I will be happy to help.
Prosenjit
Le sujet '[Fermé] Problème désactivation WPML' est fermé aux nouvelles réponses.
