[Geschlossen] Import Of Variable Products With WP All Import Does Not Work If WPML All Import Is Enabled
Sun
Mon
Tue
Wed
Thu
Fri
Sat
9:00 – 13:00
9:00 – 13:00
9:00 – 13:00
9:00 – 13:00
9:00 – 13:00
14:00 – 18:00
14:00 – 18:00
14:00 – 18:00
14:00 – 18:00
14:00 – 18:00
Unterstützt die Zeitzone: Europe/Madrid (GMT+02:00)
I am trying to import variable products with WP ALL IMPORT. The issue can be seen at versteckter Link. The import only works if WPML All Import is disabled. I am using the following server settings: memory_limit = 512M, upload_max_filesize = 150M, post_max_size = 150M. The import file is located at versteckter Link. Active plugins include WP All Import Pro, WPML All Import, and WPML Multilingual CMS. The active theme is Twenty Twenty-Five. The server error logs are empty, but the wp debug.log shows a PHP Fatal error: Uncaught Exception: No trid for product variation in secondary language, impossible to set _wcml_duplicate_of_variation in /home/www/web64.s237.goserver.host/**********/wp-content/plugins/wpml-all-import/wpml-all-import.php:328.
The import process is terminated by the server, and a critical error occurs when WPML All Import is enabled. The error message is: "Es gab einen kritischen Fehler auf dieser Website. Prüfe bitte den Posteingang deines Website-Administrators auf Anweisungen. Wenn du weiterhin Probleme hast, wende dich bitte an die Support-Foren. Erfahre mehr über die Problembehandlung in WordPress." with status 500. The PHP Fatal error in the debug log is: Uncaught Exception: No trid for product variation in secondary language, impossible to set _wcml_duplicate_of_variation.
Do you have an idea why your plugin breaks the import?
In that case, the problem was caused by duplicated products with the same SKU. Could this be the same issue you’re experiencing?
Alternatively, you might want to try our newer WPML Import/Export tool, which also supports WP All Import. You can find more details here: WPML Export and Import.
Das Thema '[Geschlossen] Import Of Variable Products With WP All Import Does Not Work If WPML All Import Is Enabled' ist für neue Antworten geschlossen.
Cookie-Zustimmung verwalten
Wir verwenden Cookies, um unsere Website und Dienste zu optimieren. Ihre Zustimmung erlaubt es uns, Daten wie das Durchsuchen der Website zu verarbeiten. Wenn Sie nicht zustimmen, können einige Funktionen beeinträchtigt werden.
Funktionell
Immer aktiv
Erforderlich für den Betrieb und die korrekte Kommunikation auf unserer Website.
Präferenzen
Statistiken
Wir verwenden diese, um die Statistiken unserer Website zu analysieren. Die gesammelten Informationen sind völlig anonym. Der technische Speicher oder Zugriff, der ausschließlich zu anonymen statistischen Zwecken verwendet wird. Ohne eine Vorladung, die freiwillige Einhaltung durch Ihren Internetdienstanbieter oder zusätzliche Aufzeichnungen von Dritten können die zu diesem Zweck gespeicherten oder abgerufenen Informationen in der Regel nicht dazu verwendet werden, Sie zu identifizieren.
Marketing
Diese Cookies verfolgen Ihr Surfverhalten, um für Sie relevante Werbung anzuzeigen.
