[Geschlossen] WPML Elasticpress: No posts found for EN index
Sun
Mon
Tue
Wed
Thu
Fri
Sat
8:00 – 13:00
9:00 – 13:00
9:00 – 13:00
8:00 – 12:00
8:00 – 12:00
14:00 – 17:00
14:00 – 18:00
14:00 – 18:00
13:00 – 17:00
13:00 – 17:00
Zeitzone des Supporters: Europe/Zagreb (GMT+02:00)
i'm using the latest versions of WordPress, WPML, Elasticpress and WPML Elasticpress. I have several custom queries (get_posts()) with the "ep_integrate" parameter in order to run the query through Elasticsearch.
While content in the main language (DE) is queried correctly, content the the secondary language (EN) does not return any results. I've run the Elasticpress indexer and there's an DE and EN index, no errors while syncing.
Does WPML elasticpress support the ep_integrate parameter?
In my opinion "WPML ElasticPress" should handle this automatically, mapping WPML's current language to the correct ElasticPress index without additional code.
Other than that I don't have more info about ep_integrate so I would need to check this with our 2nd tier.
I am wondering if something like this would help though?
add_filter('ep_formatted_args', function($formatted_args, $args) {
// Retrieve the current language code using WPML's recommended method
$current_language = apply_filters('wpml_current_language', NULL);
if ($current_language) {
// Construct the index name dynamically based on the current language
// Assuming a naming convention like 'your_prefix-post-1-<language_code>'
$index_prefix = 'your_prefix-post-1'; // Adjust this prefix according to your actual index naming convention
$language_code = $current_language; // Use the WPML function to get the current language code
// Check if the current language is English
if ($language_code === 'en') {
// Construct the full index name for English content
$english_index = $index_prefix . '-' . $language_code;
// Update the query to use the dynamically constructed English index name
$formatted_args['index'] = $english_index;
// Extend this logic for other languages as needed
return $formatted_args;
}, 10, 2);
Remember to replace 'your_prefix-post-1' with the actual prefix used in your Elasticsearch index names. This strategy ensures that all queries going through ElasticPress will automatically target the correct index for English content based on the current WPML language setting, without needing to specify exact index names in your code.
Bruno Kos
Das Thema „[Geschlossen] WPML Elasticpress: No posts found for EN index“ ist für neue Antworten geschlossen.
Cookie-Zustimmung verwalten
Wir verwenden Cookies, um unsere Website und Dienste zu optimieren. Ihre Zustimmung erlaubt es uns, Daten wie das Durchsuchen der Website zu verarbeiten. Wenn Sie nicht zustimmen, können einige Funktionen beeinträchtigt werden.
Funktionell
Immer aktiv
Erforderlich für den Betrieb und die korrekte Kommunikation auf unserer Website.
Präferenzen
Statistiken
Wir verwenden diese, um die Statistiken unserer Website zu analysieren. Die gesammelten Informationen sind völlig anonym. Der technische Speicher oder Zugriff, der ausschließlich zu anonymen statistischen Zwecken verwendet wird. Ohne eine Vorladung, die freiwillige Einhaltung durch Ihren Internetdienstanbieter oder zusätzliche Aufzeichnungen von Dritten können die zu diesem Zweck gespeicherten oder abgerufenen Informationen in der Regel nicht dazu verwendet werden, Sie zu identifizieren.
Marketing
Diese Cookies verfolgen Ihr Surfverhalten, um für Sie relevante Werbung anzuzeigen.
