WPML
Salon booking system plugin is easy to use yet, a feature-rich booking plugin. In this tutorial, you will learn how to translate Salon Booking elements using WPML.
Default language booking form (English)
Secondary language booking form (Spanish)
Getting started
Make sure that you have activated the Salon booking system plugin navigating to Plugins → Installed Plugins. Also, make sure that you have activated the WPML Multilingual CMS, WPML String Translation, and WPML Translation Management plugins.
Translating booking forms and notification emails
To translate the text of your booking form, follow these steps:
  1. Navigate to WPML → Translations → Strings.
  2. Search for the string that you want to translate.
  3. Click on the translations link, add the translation, tick the Translation is complete box, then click Save.
  4. Repeat steps (2) and (3) to translate all the form texts.
Translating forms and email notification texts
It is worth mentioning that you will find all Salon booking texts registered under the “salon-booking-system” text-domain.
You can follow the same steps to translate the notification email text.
Translating services
Translating services is very similar to translating posts and pages. For more details, check our guide on translating your website’s content using WPML’s advanced translation editor.
Getting help from our support
In case you need help translating your site built using Salon booking and WPML, ask a question in WPML support.
Written byAmir
