The client reported that the delivery time for many translated products was not set and was not copied from the source language. Even after manually setting the delivery time in the translated products, it would not save and remained empty. Additionally, the backend showed the correct translated delivery time, but the frontend displayed the delivery time in the source language.
We identified that the custom field '_default_delivery_time' was set to 'Do not translate'. We recommended setting this field to 'Copy' and then updating the translations. This setting can be found under WPML > Settings > Custom Fields, by clicking on 'Show system fields'. After making this change, the delivery times should display correctly in both the backend and frontend. If the issue persists, we advised the client to provide an exact example of what they were trying to translate.
Please note that this solution might be outdated or not applicable to your specific case. If the issue persists, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If needed, do not hesitate to open a new support ticket for further assistance.
Schlagwörter:
Dieses Thema enthält 5, hat 0 Stimmen.
Zuletzt aktualisiert von ugurA-6 Vor 1 Monat, 1 Woche.
Assistiert von: Andreas W..
Autor Beiträge
April 4, 2026 um 13:20 #17949070
ugurA-6
Hello Dear Team,
the delivery time in a lot of translated products is not set and it is not copied from the source language. Even when we choose the delivery time in the translated products manually it will not be saved and remains empty. We need to fix this ASAP because the delivery times are not shown!
April 5, 2026 um 2:05 #17949712
Sprachen: Englisch (English ) Deutsch (Deutsch )
Hallo,
Vielen Dank für deine Nachricht!
Anscheinend wurde unter WPML > Einstellungen > Benutzerdefinierte Felder übersetzen das Feld product_count_product_delivery_time auf "Übersetzen" gestellt.
Das Feld sollte auf "Kopieren" gestellt werden.
Danach müssen die Übersetzungen der betroffenen Produkte aktualisiert werden.
Mit freundlichen Grüßen
April 5, 2026 um 10:15 #17949880
ugurA-6
Hallo Andreas,
wir haben es bereits so versucht, wie du es beschrieben hast, auch anhand der Screenshots. Leider hat das Problem dadurch nicht gelöst werden können.
Wir müssen aber noch etwas Wichtiges klarstellen: Das Problem betrifft nicht jede Sprache und auch nicht jedes Produkt.
Nach unserem bisherigen Eindruck betrifft es vor allem die Produkte, bei denen wir vorher schon ein anderes Problem hatten: Diese Produkte waren in den Sprachen Niederländisch und Französisch zunächst nicht korrekt der Source Language zugewiesen, obwohl sie bereits übersetzt waren.
Zur kurzen Vorgeschichte:
Wir hatten bei einigen neu übersetzten Produkten das Problem, dass die niederländischen und französischen Versionen nicht richtig der Source zugeordnet waren. Daraufhin haben wir das manuell mit einem Hilfsplugin gelöst. Dabei haben wir die entsprechende Source-Nummer ergänzt, sodass die Produkte danach korrekt der deutschen Source zugewiesen wurden. Diese Zuordnung scheint inzwischen auch korrekt zu sein – beim Sprachwechsel wird jeweils das richtige zugeordnete Produkt geöffnet.
Trotzdem vermuten wir inzwischen, dass das aktuelle Problem mit den Lieferzeiten möglicherweise genau mit diesen manuell zugeordneten Produkten zusammenhängt. Denn nach unserem Eindruck betrifft der Fehler vor allem diese Produkte, nicht aber neu angelegte Übersetzungen, die von Anfang an sauber erstellt wurden.
Vielleicht hängt das Problem also nicht direkt mit der allgemeinen WPML-Konfiguration zusammen, sondern mit den Produkten, die damals nachträglich manuell der Source zugewiesen wurden.
Denkst du auch es könnte damit zusammen hängen?
Viele Grüße
April 5, 2026 um 10:49 #17949981
Hallo,
Ich kann gerne anbieten, mir das einmal genauer anzusehen.
Die dafür erforderlichen Felder findest du unterhalb des Kommentarbereichs, wenn Du dich anmeldest, um die nächste Antwort zu hinterlassen. Die Informationen, die du angibst, sind privat, was bedeutet, dass nur du und ich sie sehen und darauf zugreifen können.
WICHTIG
versteckter Link
Video:
versteckter Link
April 5, 2026 um 12:06 #17950007
Es gibt ein Feld namens "_default_delivery_time". Das steht aktuell auf "Nicht übersetzen". Stelle es bitte auf "Kopieren" und aktualisiere danach die Übersetzungen.
Du findest das Feld unter WPML > Einstellungen > Benutzerdefinierte Felder anzeigen, wenn du auf Systemfelder anzeigen klickst.
Ich habe es bereits auf "Kopieren" gestellt.
Sollte sich das Problem nun nach der Aktualisierung der Übersetzung nicht legen, so gib mir bitte ein exaktes Beispiel dazu, was du versuchst zu übersetzen.
Geht es um den folgenden Text?
Délai de livraison: environ 3-7 jours ouvrables
Deine Website hat zudem keinen Sprachumschalter. Benötigst du Hilfe bei der Einrichtung?
April 5, 2026 um 13:26 #17950022
ugurA-6
Hey Andreas,
danke für deine Mithilfe. Wir sind bereits einen Schritt weiter und die Lieferzeit wird jetzt im backend bei den Übersetzungen übernommen. Wir haben aber noch das Problem dass im Frontend die Source Sprache der Lieferzeit angezeigt wird. Also Die deutsche source Lieferzeit ist ca. "2-6 Werktage". Das haben wir für NL übersetzt mit "ca. 3-7 werktagen"
Im Backend wird korrekt "ca. 3-7 werktagen" angezeigt aber im frontend das deutsche 2-6 Werktage...
Beispiel produkt:
versteckter Link
April 5, 2026 um 16:54 #17950177
ugurA-6
Hey Andreas, das Problem scheint gefixt zu sein, du brauchst vorerst nichts mehr tun.
