Salta la navigazione
- 11:00 – 15:00 11:00 – 15:00 11:00 – 15:00 11:00 – 15:00 11:00 – 15:00 -
- 16:00 – 20:00 16:00 – 20:00 16:00 – 20:00 16:00 – 20:00 16:00 – 20:00 -
Fuso orario del fornitore: Europe/Rome (GMT+02:00)
Etichettato:
Questo ticket contiene 20 risposte, ha 2 voci.
Ultimo aggiornamento da Laura 1 anno, 3 mese fa.
Assistito da: Laura.
Autore Messaggi
Gennaio 24, 2024 a 3:29 pm #15222714
adrianoG-10
I'm going to finish the translation of the site. There's a part of the site I can't translate. Looking for a solution I find assistance post both from WPML and from Woodmart.
But I can't solve the issue anyway.
The part of the site I'm not able to translate is the 'Title of the mobile menu' (please look at the attached picture).
Fisrt I went to String Translation: I tried to search for the italian terms of the mobile menu titles and the to translate it. No way. Nothing found.
In your support post I found: https://wpml.org/forums/topic/translate-menu-name-of-woodmart-mobile-header/ (but unfortunately I can get no solution here)
Woodmart suggest: link nascosto
That is at first step to create a copy of the header and translate it (but I can't find how to do)
Another Woodmart support post suggest to go to string Translations and to search/find in the Domain field the admin_field_whb-header_(number of the id): but here I can't find where to traslate the menu title but just other things (please refer to attached picture).
many thanks
Gennaio 24, 2024 a 4:36 pm #15222960
Laura
Salve,
grazie per averci contattato.
Prova tutto quello che è suggerito qui https://wpml.org/it/documentazione/guida-introduttiva/string-translation/trovare-le-stringhe-che-non-appaiono-nella-pagina-string-translation/
Gennaio 24, 2024 a 6:27 pm #15223268
adrianoG-10
Ciao Laura,
ho usato 'Le stringhe non vengono selezionate per la traduzione', ho trovato quindi le due stringe (testo ACQUISTA e testo SCOPRI), in effetti le trova dove dovrebbero essere ovvero legate al whb_header_153799 (che è l'header che uso). una volta inserite le ho tradotte. Ero ottimista, ma non funziona. I titoli dei menu rimango non tradotti (pulito cache e tutto quanto...). Forse mi sbaglio ma credo che il motivo sia che quell'header in sé non è tradotto. Quindi WPML forse pur conoscendo la traduzione non la applica. Infatti nel messaggio che ti ho inviato Woodmart suggerisce di tradurre proprio l'header (non spiega poi come...). Putroppo nel mio sito queste posizioni da tradurre sono molto importanti perché riguardano il menu primario. ti allego l'evidenza che ho proceduto come richiesto e che non è tradotto
Gennaio 25, 2024 a 8:12 am #15224729
adrianoG-10
Aggungo anche di aver provato in WPML->Impostazioni ad aggiungere come traducibili le 'header' create in header builder. Ma non ho trovato qualcosa che facesse riferimento a quella parte del template.
Ho poi trovato questo post di WPML per risolvere Il problema del solo secondo titolo-bottone https://wpml.org/forums/topic/translating-secondary-button-mobile-menu/page/2/.
posto che mi servirebbe la soluzione anche per il primo, seguendo il tutorial proposto non riesco a capire cosa si intende per "scan the theme from WPML > Theme and Plugins Localization" (non trovo un tasto scan o simili). Grazie
Gennaio 25, 2024 a 11:34 am #15225823
Laura
I template non si traducono in Traduzione Stringhe, se lo fai è normale che non si veda nulla. Dovrebbe esserci una voce "template" o "header" in Gestione Traduzioni.
Gennaio 25, 2024 a 11:49 am #15225896
adrianoG-10
Ciao Laura, sono molto perplesso.
la voce 'template' in gestione traduzioni c'è, 'header' no.
selezionando Template e scorrendo le pagine della lista non si trova header.
Rispetto a al fatto che i template non si traducono in traduzione stringhe ti allego lo screenshot dove è indicato da WPML come procedere proprio in questo modo, mi hai girato tu il link: https://wpml.org/it/documentazione/guida-introduttiva/string-translation/trovare-le-stringhe-che-non-appaiono-nella-pagina-string-translation/
Ti allego lo screen shot.
Gennaio 25, 2024 a 11:56 am #15225969
Laura
Mi mandi le credenziali del sito?
Gennaio 25, 2024 a 4:50 pm #15227540
adrianoG-10
Ciao Laura,
puoi confermarmi che stai lavorando sul sito, solo per essere sicuro che i plugin disattivati sono dovuti al tuo intervento. Grazie, scusa l'ansia
Gennaio 25, 2024 a 4:56 pm #15227561
Laura
Prova a riprodurre il problema qui link nascosto
Gennaio 25, 2024 a 5:44 pm #15227675
adrianoG-10
Ciao,
scusa, non ho capito bene. Non trovo la stessa struttura in questo tema.
Le due colonne di menu con titoli diversi sono nel tema Woodmart.
Ho visto che hai fatto un test con tutti i plugin disattivati. Quindi in buona sostanza non c'erano possibili conflitti.
Potresti indicarmi la nomale procedura per ottenere la traduzione di quella parte del sito per step. Così posso eventualmente indicarla allo staff di Woodmart. Cioè come si farebbe normalmente?
Grazie
Gennaio 25, 2024 a 6:46 pm #15227856
Laura
I plugin li ho riattivati.
Nella Sandbox devi installare Woodmart e ricreare il problema, io non ho una copia del tema per fare i test.
Gennaio 30, 2024 a 12:52 pm #15243692
adrianoG-10
Ciao Laura,
prima di passare alla fase Sandbox', ho provato a seguire un tutorial di un tuo collega:https://wpml.org/forums/topic/translating-secondary-button-mobile-menu/
non è proprio così lineare come indicato, ma alla fine ho ottenuto la traduzione (estendendo lo script analogamente anche anche alle righe del primary.
In questo modo sono riuscito a fare la traduzione. Mi chiedo però se non hai consigliato questa stessa soluzione perché ha degli effetti collaterali o crea problemi che è meglio evitare.
Grazie.
Gennaio 30, 2024 a 1:14 pm #15243908
Laura
Non la conoscevo, ma non dovrebbe essere necessario fare quel processo. L'autore ha detto che è stato risolto da loro più di 10 mesi fa. Il tema è aggiornato?
Se sì, ti consiglio di contattare Woodmart e chiedere a loro se per caso non abbiano sbagliato ad inserirlo nell'ultima versione.
Febbraio 2, 2024 a 12:25 pm #15259219
adrianoG-10
Ciao Laura,
ho aggiornato il tema ma ho dovuto ricorrere allo stesso trucchetto del tuo collega per risolvere visto che il tema aveva resecato il file php su cui avevo aggiunto il codice.
Sono poi passato a tradurre il logo. Probabilmente essendo nello stesso elemento di layout (un tipo di header), il logo non si traduce, cioè non viene visualizzata l'immagine del logo (quello in versione inglese. Ho provato sia con Media Translation (vedi allegato) sia con String Translation (vedi allegato).
Ovviamente il dubbio è che si debba ricorrere alla stessa procedura come per i titoli del menu. Ovviamente però non so dove nel codice.
È magari possibile avere un aiuto dal tuo collega che aveva dato quella risposta? https://wpml.org/forums/topic/translating-secondary-button-mobile-menu/ (leggo Faisal Ahammad).
Grazie mille.
Febbraio 2, 2024 a 2:57 pm #15259785
Laura
Il collega non lavora più qui, ma comunque non l'aveva creato lui il codice. Il team di Woodmart però ci aveva sconsigliato di usare quel tipo di soluzione, per cui ti suggerirei di rivolgerti a loro
L'argomento '[Chiuso] Header bulider Menu Title – Translation issue with Woodmart theme' è chiuso a nuove risposte.
