[Gelöst] Issue with losing URL translations when editing primary language (Kadence Blocks)
Problem: If you're experiencing issues where the translated English URL of elements like the Kadence Advanced Button reverts to the default language URL after making edits to the German version of your page, this might be due to incorrect XML configuration for translating URLs within Gutenberg blocks. Solution: We recommend updating the Custom XML configuration for the Kadence Blocks. Here's the updated XML you should use:
<wpml-config><br /> <gutenberg-blocks><br /> <gutenberg-block type="kadence/singlebtn" translate="1"><br /> <key name="link" type="link"></key><br /> <key name="text"></key><br /> </gutenberg-block><br /> <gutenberg-block type="kadence/advancedheading" translate="1"><br /><xpath>//*[self::h1 or self::h2 or self::h3 or self::h4 or self::h5 or self::h6 or self::p or self::div or self::span.wp-block-kadence-advancedheading]</xpath><br /> <xpath type="link">//a/@href</xpath><br /></gutenberg-block><br /> </gutenberg-blocks><br /></wpml-config>
Please insert this XML in WPML > Settings > Custom XML. After updating, make a minor edit to the original post and save it. Check the translation again; the internal links should now automatically translate and not appear inside the translation editor.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your specific case, we highly recommend checking the related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should the problem persist, please open a new support ticket.
Hintergrund des Themas:
I have two languages on my website: primary language German and secondary language English. I am using Kadence Blocks, and my website is fully translated and error-free. I am trying to make minor changes to a German subpage, such as adjusting spacing. Link to a page where the issue can be seen: versteckter Link
Die Symptome:
After making small changes to the German version, I lose the translated English URL of elements like the Kadence Advanced Button. The URL reverts to '/kontakt/' instead of '/en/contact-us/'. I need to manually fix the URL translation by searching for '/kontakt/' and replacing it with '/en/contact-us/' in the translated page. This issue repeats every time I make further edits to the German version. The same problem occurs with URL translations of text links.
Screencast: versteckter Link
Fragen:
Why do I lose the translated English URL when editing the German version?
How can I prevent URL translations from reverting when making changes?
Thank you so much for cooperating. I've escalated your ticket to our development team. They'll search for a solution, which usually takes a week. I'll let you know once I have new information.
Thank you for your patience. Let me explain what's the expected behavior here:
WPML should always translate the internal links automatically, when a translation is finished. That means that the internal link will NOT show inside the translation editor. Only links that point to other, external websites, will be available inside the translation editor.
We found out that there's a small mistake in the XML provided by Kadence, which makes you face the issue you're facing. TO fix that, please make a full website backup and follow these steps:
1. Go to WPML > Settings > Custom XML configuration
2. Add this code:
3. Save
4. Make a small change in the original page, where the button is. You can add a blank space to a text, for example;
5. Update the translation. No need to change anything.
Now, the link should be always pointing to the correct internal translated page. External links should be available inside the editor. Let me know.
Will you inform Kadence about ther "mistake"? Because it is not happening only with the Button it is the Link in the advanced Text block too:
<!-- /wp:kadence/advancedheading -->
XML from Kadence Blocks:
</gutenberg-block>
I'm glad to hear that. We are already checking the fix and communicating them. I'm waiting to see if there's a fix for the link inserted in the text element.
I got feedback from our devs. They updated the Custom XML for the button and the text link you were having issues with:
<wpml-config>
<gutenberg-blocks>
<key name="link" type="link" />
<key name="text" />
</gutenberg-block>
</gutenberg-block>
</gutenberg-blocks>
</wpml-config>
Please update that part on WPML > Settings > Custom XML, make a small change in the original post and save. Finally, check the translation again. The internal links should be translated automatically after saving the translation. They should not show inside the translation editor. Let me know.
I'm not sure about that. It's likely that the previous custom XML was causing some unexpected behavior.
Cookie-Zustimmung verwalten
Wir verwenden Cookies, um unsere Website und Dienste zu optimieren. Ihre Zustimmung erlaubt es uns, Daten wie das Durchsuchen der Website zu verarbeiten. Wenn Sie nicht zustimmen, können einige Funktionen beeinträchtigt werden.
Funktionell
Immer aktiv
Erforderlich für den Betrieb und die korrekte Kommunikation auf unserer Website.
Präferenzen
Statistiken
Wir verwenden diese, um die Statistiken unserer Website zu analysieren. Die gesammelten Informationen sind völlig anonym. Der technische Speicher oder Zugriff, der ausschließlich zu anonymen statistischen Zwecken verwendet wird. Ohne eine Vorladung, die freiwillige Einhaltung durch Ihren Internetdienstanbieter oder zusätzliche Aufzeichnungen von Dritten können die zu diesem Zweck gespeicherten oder abgerufenen Informationen in der Regel nicht dazu verwendet werden, Sie zu identifizieren.
Marketing
Diese Cookies verfolgen Ihr Surfverhalten, um für Sie relevante Werbung anzuzeigen.
