This topic contains 12 replies, has 0 voices.
Last updated by Kor 9 hours, 59 minutes ago.
June 25, 2025 at 8:48 pm #17170879
vitoG-4
I am trying to ensure that the featured image assigned to a post is visible in all translated versions of that post, not just in the original English version. Here is a link to a page where the issue can be seen: hidden link
The featured image is only visible in the original language (English). In the translated versions, it either disappears or remains outdated, even after syncing the content. Additionally, when I enable the option 'Media (attachment)' as translatable in WPML settings, profile photos on user profiles disappear in any language other than English.
How can I configure WPML to ensure that featured images are synced across all translations?
Why do profile photos disappear in languages other than English when 'Media (attachment)' is set as translatable?
June 26, 2025 at 1:46 am #17171097
WPML Supporter since 08/2022
Thanks for contacting us. I've checked your Website and I can see the missing featured images. Please try to run the media translation sync option in WPML > Settings > Media Translation > Click Start. Before you do that, make sure the option "Duplicate the featured images for translated content" is checked, as shown in the attached screenshot. Let me know how it goes.
June 26, 2025 at 12:08 pm #17173379
vitoG-4
Hello Kor,
I followed your suggestions, but the blog post remained unchanged. No Photo appears in other languages.
I have a test site. If you want, I can give you access.
Let me know.
June 26, 2025 at 1:42 pm #17173923
Thanks for your reply.
June 26, 2025 at 2:37 pm #17174279
Thanks for your reply. You need to allow translations for your medias as shown in the attached screenshot in WPML > Settings > Post Types Translation. Once you've done that, please try to run the media translation sync option in WPML > Settings > Media Translation > Click Start.
June 26, 2025 at 2:44 pm #17174307
vitoG-4
I did it AGAIN, but the blog post remained unchanged. No Photo appears in other languages.
Try it yourself, it's a test site. Don't worry.
Check Portuguese or Spanish, English is not affected.
IMPORTANT: When I enable the 'Media (attachment)' option as translatable in WPML settings, profile photos on user profiles disappear in all languages except English.
Let me know.
June 26, 2025 at 2:49 pm #17174318
Thanks for your reply. Could you please check why the featured image is not showing on the primary language, English? hidden link
June 26, 2025 at 3:05 pm #17174349
vitoG-4
maybe some migration error. I replace the image in this post, and now works correctly
June 26, 2025 at 3:29 pm #17174469
Thanks for your reply. I can see the broken images are pointing to hidden link . Could you backup and perform a search and replace to correct the image links?
June 26, 2025 at 5:16 pm #17174893
vitoG-4
Please check, now the featured images in English are all ok.
In other languages, some people work and others do not, specifically the Portuguese language is more affected.
June 26, 2025 at 5:22 pm #17174899
Thanks for your reply. When I checked, I can see the images are pointing to Amazon AWS but were blocked, showing "Access Denied" as shown in this screen recording. Are you able to fix it? hidden link
June 26, 2025 at 6:25 pm #17174963
vitoG-4
Hello Kor,
You should check the English post.
The problem is that this image does not exist, WPML does not override it with a new image, and you receive an 'access denied' error because the link is incorrect.
The idea is that WPML should override with a new image that I posted in English posts.
As I mentioned, it's a test that allows you to enter posts and try to save them in other languages.
June 27, 2025 at 3:55 pm #17178235
Thanks for your reply. I understand the issue now. It seems that in the translated posts, the featured image is already set, so WPML assumes everything is fine and skips over it. To resolve this, we need to remove the existing featured images from the translated versions so that WPML can properly copy them again from the original language page: hidden link
