The client reported that their Italian website was not working, while the German, French, and English versions were functioning correctly. They provided a PHP Fatal error log indicating an ArgumentCountError in the Avada theme's files.
We recommended that the client install the String Translation add-on for WPML. This would allow us to scan the translation files and investigate the issue with the specific string mentioned in the error log. The problem seemed to be related to an issue with the Avada translated .po file, similar to a known issue discussed in our support forum.
If you're experiencing a similar issue, we recommend you try installing the String Translation add-on from your WPML account. Once installed, you can scan your translation files for any inconsistencies or errors that might be causing the problem.
Please note that the solution provided might be irrelevant due to it being outdated or not applicable to your case. If after trying the recommended steps the issue persists, we highly recommend checking the related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still need assistance, please do not hesitate to open a new support ticket in the WPML support forum.
Schlagwörter:
Dieses Thema enthält 6 Antworten, hat 2 Stimmen.
Zuletzt aktualisiert von Bruno Kos Vor 1 Jahr, 8 Monaten.
Assistiert von: Bruno Kos.
Autor Beiträge
April 3, 2024 um 9:59 a.m.
carinaJ
Italian website does not work
April 3, 2024 um 10:07 a.m. #15477342
Bruno Kos
Zeitzone: Europe/Zagreb (GMT+01:00)
Can you do this:
1. Edit wp-config.php and insert the following lines (just before /* That's all, stop editing! Happy publishing. */ part)
define( 'WP_DEBUG', true);
define( 'WP_DEBUG_LOG', true);
define( 'WP_DEBUG_DISPLAY', false);
2. Reproduce the issue - visit versteckter Link
3. Locate the debug log in: /wp-content/debug.log
4. Paste the latest lines here. No need to paste the entire log file, just 10 lines or so will do. Please censor any sensitive information.
https://codex.wordpress.org/Debugging_in_WordPress
April 3, 2024 um 10:10 a.m. #15477351
carinaJ
Thanks! Here:
[03-Apr-2024 10:09:02 UTC] PHP Fatal error: Uncaught ArgumentCountError: 3 arguments are required, 2 given in /home/www/speckeria.at/wp-content/themes/Avada/includes/metaboxes/tabs/tab_header.php:83
Stack trace:
#0 /home/www/speckeria.at/wp-content/themes/Avada/includes/metaboxes/tabs/tab_header.php(83): sprintf('Scegliere di im...', ' Impostazione p...')
#1 /home/www/speckeria.at/wp-content/themes/Avada/includes/metaboxes/metaboxes.php(270): avada_page_options_tab_header(Array)
#2 /home/www/speckeria.at/wp-content/themes/Avada/includes/class-fusion-dynamic-css-from-options.php(160): PyreThemeFrameworkMetaboxes->get_options()
#3 /home/www/speckeria.at/wp-content/themes/Avada/includes/class-fusion-dynamic-css-from-options.php(126): Fusion_Dynamic_CSS_From_Options->init('PO')
#4 /home/www/speckeria.at/wp-includes/class-wp-hook.php(324): Fusion_Dynamic_CSS_From_Options->dynamic_css_array_filter_po(Array)
#5 /home/www/speckeria.at/wp-includes/plugin.php(205): WP_Hook->apply_filters(Array, Array)
#6 /home/www/speckeria.at/wp-content/themes/Avada/includes/lib/inc/class-fusion-dynamic-css-helpers.php(390): apply_filters('fusion_dynamic_...', Array)
#7 /home/www/speckeria.at/wp-content/themes/Avada/includes/lib/inc/class-fusion-dynamic-css.php(306): Fusion_Dynamic_CSS_Helpers->get_dynamic_css()
#8 /home/www/speckeria.at/wp-content/themes/Avada/includes/lib/inc/class-fusion-dynamic-css-helpers.php(374): Fusion_Dynamic_CSS->generate_final_css()
#9 /home/www/speckeria.at/wp-content/themes/Avada/includes/lib/inc/class-fusion-dynamic-css-file.php(113): Fusion_Dynamic_CSS_Helpers->get_dynamic_css_id()
#10 /home/www/speckeria.at/wp-content/themes/Avada/includes/lib/inc/class-fusion-dynamic-css-file.php(180): Fusion_Dynamic_CSS_File->file('filename')
#11 /home/www/speckeria.at/wp-content/themes/Avada/includes/lib/inc/class-fusion-dynamic-css-file.php(55): Fusion_Dynamic_CSS_File->can_write()
#12 /home/www/speckeria.at/wp-content/themes/Avada/includes/lib/inc/class-fusion-dynamic-css.php(212): Fusion_Dynamic_CSS_File->__construct(Object(Fusion_Dynamic_CSS))
#13 /home/www/speckeria.at/wp-includes/class-wp-hook.php(324): Fusion_Dynamic_CSS->init('')
#14 /home/www/speckeria.at/wp-includes/class-wp-hook.php(348): WP_Hook->apply_filters(NULL, Array)
#15 /home/www/speckeria.at/wp-includes/plugin.php(517): WP_Hook->do_action(Array)
#16 /home/www/speckeria.at/wp-includes/script-loader.php(2265): do_action('wp_enqueue_scri...')
#17 /home/www/speckeria.at/wp-includes/class-wp-hook.php(324): wp_enqueue_scripts('')
#18 /home/www/speckeria.at/wp-includes/class-wp-hook.php(348): WP_Hook->apply_filters('', Array)
#19 /home/www/speckeria.at/wp-includes/plugin.php(517): WP_Hook->do_action(Array)
#20 /home/www/speckeria.at/wp-includes/general-template.php(3050): do_action('wp_head')
#21 /home/www/speckeria.at/wp-content/themes/Avada/header.php(21): wp_head()
#22 /home/www/speckeria.at/wp-includes/template.php(810): require_once('/home/www/speck...')
#23 /home/www/speckeria.at/wp-includes/template.php(745): load_template('/home/www/speck...', true, Array)
#24 /home/www/speckeria.at/wp-includes/general-template.php(48): locate_template(Array, true, true, Array)
#25 /home/www/speckeria.at/wp-content/themes/Avada/100-width.php(15): get_header()
#26 /home/www/speckeria.at/wp-includes/template-loader.php(106): include('/home/www/speck...')
#27 /home/www/speckeria.at/wp-blog-header.php(19): require_once('/home/www/speck...')
#28 /home/www/speckeria.at/index.php(17): require('/home/www/speck...')
#29 {main}
thrown in /home/www/speckeria.at/wp-content/themes/Avada/includes/metaboxes/tabs/tab_header.php on line 83
Regards
April 3, 2024 um 11:07 a.m. #15477651
Bruno Kos
Can you install String Translation?
versteckter Link
I believe this to be the same issue as https://wpml.org/forums/topic/spanish-translation-has-vanished-only-blank-page-appears/page/2/#post-9858729, so something within the Avada translated .po file.
I need String Translation so I could scan the translation files and see about this string there.
April 3, 2024 um 11:40 a.m. #15477780
carinaJ
Thanks! String Translation has been installed.
April 3, 2024 um 11:51 a.m. #15477898
carinaJ
I uploaded the Avada po file via FTP - now it works. with you, too? Thanks
April 3, 2024 um 12:07 p.m. #15478028
Bruno Kos
Yes, I can confirm that versteckter Link works for me as well.
