Salta la navigazione
Questo ticket contiene 5 risposte, ha 3 voci.
Ultimo aggiornamento da Laura 8 mese, 4 settimana fa.
Assistito da: Laura.
Autore Messaggi
Luglio 15, 2024 at 10:50 am #15953751
Marco
Contesto del problema:
for the second time the second languages (english) is not longer work ... according to mu hosting service this is the problem WPML set the rewrite rules like this:
RewriteEngine On
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteBase /en
RewriteRule ^index.php$ - [L]
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule . /en/index.php [L]
my hosting service rewrite the rules like this
RewriteEngine On
RewriteBase /
RewriteRule . /index.php [L]
I'm scare the wpml will rewrite the wrong rules and 2d language will fall apart again ... Please investigate
Sintomi:
Domande:
Luglio 15, 2024 at 11:01 am #15953804
Marcel
Lingue: Inglese (English ) Tedesco (Deutsch )
Fuso orario: Europe/Madrid (GMT+02:00)
Before your ticket is assigned to one of my colleagues, please allow me to guide you through some initial debugging steps. This will help expedite the support process.
The issue you're experiencing is typically not caused by WPML itself but rather by third-party code that calls flush_rewrite_rules too frequently. This can lead to the .htaccess file being overwritten with incorrect settings, as explained in this article:
Why is .htaccess getting overwritten with the language folder on my WPML website?.
Does this workaround solve the issue for you?
Best Regards
Marcel
Luglio 15, 2024 at 12:17 pm #15954336
Marco
Hi, thank you for helping, I don't think this work around can fix the issue because we did it a month ago about and the problem has occur again... do you think could be due to third part plugins? Thanks
Luglio 15, 2024 at 12:29 pm #15954385
Laura
Salve,
grazie per averci contattato.
Se non usi un tema child (e dalle informazioni di debug sembra essere così), ogni volta che aggiorni Divi il file functions.php viene sovrascritto e il codice aggiunto cancellato. Quindi se il problema si è ripresentato è probabilmente dovuto a quello.
Nella nostra esperienza il problema del flush rewrite è sempre causato da un plugin di terze parti. Fai un test disabilitando tutto e riattivando i plugin uno alla volta.
Luglio 15, 2024 at 12:39 pm #15954408
Marco
Ciao Laura, ma quindi dici che se disattivo i plugin e li riattivo e il problema non si presenta non di pende da questi? Poi in realta ho molti siti con wpml che usano gli stessi plugins ce ne sono un paio che uso qui esclusivamente potrebbero essere questi e non sono essenziali posso disattivarli ...
l'importante e capire se questo tipo di problema è esclusivamente legato ai plugins o se puo dipendere dal divi theme che va reinstallato magari è corrotto o lo stesso wp ?
Grazie
Luglio 15, 2024 at 12:48 pm #15954463
Laura
Non ci risultano problemi di questo tipo legati a Divi, è un tema che testiamo ad ogni uscita ed è tra i più usati in assoluto, se ci fosse qualcosa che interferisce con le rewrite rules lo sapremmo. Stesso discorso per WordPress.
Luglio 15, 2024 at 1:22 pm #15954676
Marco
Grazie Laura lavorerò sui plugins vediamo se dipende da questi. Un saluto
Marco
