The client was unable to translate a specific string on their website, even after deleting the string from the string translation list, rescanning the theme, and clearing the WPML cache. The string would appear translated only when the 'scan while browsing' option was activated, but would revert to being untranslated when this option was deactivated.
We recommended ensuring that the text in the Pricing section was correctly implemented for translation support. Specifically, the text should be wrapped in the Gettext function with the appropriate text domain. We provided a guide to help with this process: Translating the Theme You Created.
Further steps included:
1. Navigating to "WPML > Theme and Plugins Localization".
2. Ensuring that the Localization options were selected and the text domain of the theme was added.
3. Scanning the theme again for strings.
4. Checking the string translation section to see if the string appeared.
If these steps do not resolve the issue or if the solution seems outdated or irrelevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket.
Este tema deriva de https://wpml.org/es/forums/topic/problem-translating-complianz-cookie-banner-strings-only-works-with-search-strings-while-processi/
Este tema contiene 3 respuestas, tiene 2 voces.
Última actualización por hace 1 año, 8 meses.
Asistido por: Prosenjit Barman.
