Schlagwörter: Not WPML issue
Dieses Thema enthält 6 Antworten, hat 3 Stimmen.
Zuletzt aktualisiert von Mateus Getulio Vor 1 Jahr, 10 Monaten.
Assistiert von: Mateus Getulio.
Verfasser | Beiträge |
Januar 25, 2023 unter 6:47 am #12886315 | |
sabrinaU |
Hello, attached you can find screenshots of the issue. EN is right – DE is in a different „wrong“ layout. The issue occurs on all german pages: versteckter Link English ones look good: versteckter Link I already was in contact with the Elementor Pro Support, they told me the following: "In this case, your translation plugin (WPML) is changing how your texts are displayed. In the native language of your site, you can see that the Elementor widget will output the text without any other wrapping HTML tag than a <div> one. However, in the secondary language, you'll notice that the translated text will be wrapped on a <p> (paragraph) tag, and your third-party theme is applying a custom style (margin-bottom: 20px) on the <p> tags. I apologize; however, custom code/CSS, general WordPress issues, Beta testings, server issues, or third-party plugins/themes-related issues are out of our support scope: versteckter Link Please reach out to the WPML team so they can assist you with why the translated texts are getting wrapped on a <p> tag when they're not supposed to." Thank you for your support. |
Januar 25, 2023 unter 7:30 am #12886521 | |
Sumit Supporter
Sprachen: Englisch (English ) Zeitzone: Asia/Kolkata (GMT+05:30) |
Hi, Thank you for contacting the support forum. It seems to be a known issue. Could you please try the following workaround? 1. Make sure you have a complete backup of site files and database. add_filter( 'widget_block_content', [ $this, 'filterByLanguage' ], - PHP_INT_MAX, 1 ); with add_filter( 'widget_block_content', [ $this, 'filterByLanguage' ], 0 ); 3. Then update the original page and translate again. If this is the same problem then it should fix this issue. This problem will be fixed in the next release of WPML. Thanks |
Januar 30, 2023 unter 7:48 am #12918813 | |
sabrinaU |
Hello, I did the steps but it still looks wrong unfortunately. What else can I do? |
Januar 30, 2023 unter 9:04 pm #12924843 | |
Mateus Getulio Supporter
Sprachen: Englisch (English ) Portugiesisch, Brasilien (Português ) Zeitzone: America/Sao_Paulo (GMT-03:00) |
Hello there, Thanks for your reply. I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. You will find the needed fields for this below the comment area when you log in to leave your next reply. The information you will enter is private which means only you and I can see and have access to it. Our Debugging Procedures I will be checking various settings in the backend to see if the issue can be resolved. Although I won't be making changes that affect the live site, it is still good practice to backup the site before providing us access. In the event that we do need to debug the site further, I will duplicate the site and work in a separate, local development environment to avoid affecting the live site. Privacy and Security Policy We have strict policies regarding privacy and access to your information. Please see: **IMPORTANT** - Please make a backup of site files and database before providing us access. Please, let me know if you need any additional details. Have a nice day. |
Januar 31, 2023 unter 10:17 pm #12933539 | |
Hey there, Thank you for providing the website credentials. The Elementor support team mentioned about a possible issue with the theme. By chance, have you tried to switch it to a default one (like twenty twenty) and check if the issue remains? Further, do you allow us to migrate the website to a copy version hosted on our servers? In order to make more tests without compromising the original website. Please keep us posted. Thanks! |
Februar 1, 2023 unter 2:09 pm #12938975 | |
sabrinaU |
Hi, as we currently do not have a test environment yet, I did not change the theme because I didn't want to destroy the page. Yes, please go on and copy in order to make more tests. Thank you very much! |
Februar 1, 2023 unter 9:16 pm #12942087 | |
Hey there, Thanks for your confirmation. We have copied the website to our Cloudways servers, please check it: versteckter Link (you can login using the same credentials as the original website). You'll see that the blue bar on the German version is fitting well on the screen, and this is due to the theme change. In the CW app we have switched it to a default theme - after this, the issue does not happen anymore. Having said that, we can conclude that the problem is coming from the OceanWP theme, and not WPML. In this case, may I kindly ask you to contact the theme support and address the issue with them? I'm afraid that they'll be more able to spot the issue and check what might be the conflict. Thanks for your understanding. |
