WooCommerce Multilingual is a very important project for us, today we are happy to announce that we have 3 WooCommerce Extensions to add to our compatibility list.
The extensions are Multibanco, Advanced product labels, Catalog mode
Multibanco (IfthenPay gateway) for WooCommerce
This plugin allows Portuguese costumers to pay WooCommerce orders with Multibanco (Pag. Serviços), using the IfthenPay payment gateway.
Create custom product labels easily and quickly to grab your customer’s attention.
YITH WooCommerce Catalog mode
Add a catalog mode for your WooCommerce products
