In a quick release, just before the holidays, we updated WPML for better compatibility (and performance) with Gutenberg. If you’re looking to experiment with Gutenberg in your free time, the new Toolset Types will make it much easier.
We are now two weeks after WordPress 5.x was initially released with the new Gutenberg editor. This time allowed us to notice a number of issues and improvements. WPML 4.1.3 addresses all these issues and makes working with Gutenberg more convenient.
Most of the change is to how WPML sets the language. Previously, we filtered the new REST calls that Gutenberg relies on. We found that this causes compatibility problems with a number of plugins (most noticeable with Avada and Elementor). It also caused Gutenberg to run slower. We learned from this and changed the way WPML works. Now, there’s no speed impact and no room for conflicts with plugins that also filter Gutenberg actions.
With the experience that we’ve accumulated over the last two weeks, we feel a lot more confident about using Gutenberg editor. While we still don’t recommend doing last-minute updates to production sites, there’s a much smaller chance of things breaking due to using WordPress 5.x.
To make it easier to experiment with the new block editor, we updated Toolset Types plugin, which you can download from your WPML account. This update of Types allows you to control on which types and pages to use Gutenberg. This way, you can enable Gutenberg on any page, try it and quickly revert to the classic editor if you want.
We hope that you have a great holidays season. Please let us know in the comments what you think and if you have any questions or suggestions.
I don`t understand sense of Gutenberg still
Kindest regards,
V
Hi Amir,
I use Fusion Builder from Avada themes.
Will it work there!? Now is showing error. Everytime I must deactivate WPML if I want edit something.
I check WP site but there’s no any WPML update?
Kind regards.
Ivana
Hello Ivana.
In the hotfix version we’ve just released, we have fixed an issue which was affecting Fusion Builder as well.
I don’t know the details of the issue you are facing, therefore, I can’t tell you if your specific issue will be fixed, but I recommend you to check if the problem is gone after updating.
Please let us know how it goes. If the issue is still present, we will do our best to fix it.
Still long running compatibility issue with Elementor continues even in the latest WPML release. ?
Yes, we know that there are a number of open issues. We try to handle everything as fast as we can. Sometimes things are not entirely under our control.
Can I safely keep updating WPML even though I haven’t updated to WordPress 5 yet?
Yes. WPML works fine on the newest versions of WordPress and on older versions.
