This topic contains 12 replies, has 1 voice.
Last updated by Dražen 5 months ago.
Assisted by: Dražen.
April 27, 2025 at 12:12 pm
tuncayO-2
I am building a multilingual WooCommerce store using Elementor and WPML with separate domains per language. My Romanian default Products (Shop) page uses the slug 'produs', but the Product Base URL is incorrectly showing as 'produs' across all languages. I manually translated the Product Base slugs under WooCommerce Multilingual > Store URLs, but live links still show /produs/ instead of the correct translation. I also recreated a Shop page but Elementor does not allow me to edit the Romanian Products page ('Produse') normally. Products appear on the Romanian site, but on other domains, no products are showing under the Shop page.
Product Base URL is incorrectly showing as 'produs' across all languages instead of the correct translation. Elementor does not allow editing of the Romanian Products page. Products are not showing on other language domains.
How can I ensure the Product Base slug is correctly translated and displayed across all languages?
Why is Elementor not allowing me to edit the Romanian Products page?
How can I make products appear on the Shop page for other language domains?
April 27, 2025 at 6:27 pm #16972651
tuncayO-2
One of the person I found from upwork.com found that when we deactivate WPML string then the problem is resolved. So problem is this.
April 28, 2025 at 10:51 am #16974403
tuncayO-2
Hello
Somebody from upwork started earlier and solved the issue for now with adding jet engine query builder. I dont know what it means but it worked. I dont know I guess WPML team is still working on it. So you need to know this detail.
April 28, 2025 at 10:08 pm #16976819
Bobby
WPML Supporter since 04/2015
While waiting for one of my colleagues to be assigned to your ticket,
It sounds like you were able to resolve the issue, correct?
If yes, please verify that the WPML String Translation plugin is activated as you would not want that add-on plugin deactivated.
Also, if the issue is resolved now, we can close the ticket and if further assistance from our team or the issue returns we can review this again.
April 29, 2025 at 6:45 am #16977286
tuncayO-2
Hello
We used another plugin the solve the issue of WPML String. I would like WPML team to understand what is the problem with WPML string and to solve it o to be depend on another plugin.
It takes too much time to reach WPML support and I am trying to find support from website like fiverr or upwork. So we dont close the ticket and we find the root of the problem to solve. I would like WPML technical team to find out what is the problem.
Thank you
May 2, 2025 at 6:53 am #16987987
Dražen
sure, we would be glad to further check the issue and see what is wrong.
1) Please share steps on how can I see the issue? I tried the steps my colleagues left, but it seems to work fine and all products show for me.
2) If possible, please share the staging site, so we can safely check and debug the issue there and not on live website.
Drazen
May 5, 2025 at 8:08 am #16995107
tuncayO-2
2 weeks ago, i talked with chat, Somebody tried and after I forwarded case to another person. They uploaded WPFile manager etc, tried something but nothing came as feedback.
You have all credentials. With jet engine, I try to make it work but When I add product, again same problem exist.
Can you please help, it has been 2 weeks.
May 5, 2025 at 8:29 am #16995194
Dražen
I do not see any other open related ticket, so we would need to continue with this and follow my reply so I can better understand the issue and help out further.
As said in my last reply:
1) Please share step by step guide on how can I see the issue.
2) Please create a staging site (you can use WP staging) and share with me admin and FTP access so I can safely check the issue.
Drazen
May 5, 2025 at 11:09 am #16995782
tuncayO-2
If you go to shop pages in the different languages, you will see that products are disapearing. Only when I deactivate WPML string plugin than the issue is resolved. We can see only in English and French version the products.
WPMl told they will come back with email but nothing came, in this time i tried with upwork some developers. They found temporary solutions. But still same problem exist.
I created staging site
Do you want me to share from here credetials or if you have email, I can add you as user.
May 6, 2025 at 6:09 am #16999136
Dražen
1) Please share admin access and FTP to the staging site so I can check and debug issue further.
2) Please explain, what do you mean by product disappearing? Please share some exact examples. You can share video to explain it better.
Since I am checking EN shop page and I can see all of the products.
Drazen
May 9, 2025 at 10:45 am #17016021
Dražen
thanks, but I need admin access details so I can access the different domains' admin dashboard and check settings and translation.
I can now login only to .com from your hosting account.
Please share it in next private reply.
Drazen
May 9, 2025 at 10:53 am #17016047
Dražen
I forgot to say, please share access to the staging site, you said it was created. So I can do proper debugging and see what is wrong.
Drazen
May 9, 2025 at 1:23 pm #17016890
Dražen
Thanks, but I have not received any image so I am still stuck on proceeding.
Can you please share the URL of the staging site?
Drazen
May 9, 2025 at 1:37 pm #17016953
tuncayO-2
Here it is.
All is ok now i guess
May 9, 2025 at 2:04 pm #17017061
tuncayO-2
Just as a note,
I worked in the mean time with someone from upwork. He used jetengine query builder. Did something. And it is solved partially. When I added a product .com.tr site only, it is broken again. I am saying partially because I could see product in all languages but add to carts buttons were invisible in all languages but only in english .com version.
